View unanswered posts | View active topics It is currently June 25th, 2025, 9:22 pm
Reply to topic  [ 3991 posts ]  Go to page Previous  1 ... 79, 80, 81, 82, 83, 84, 85 ... 400  Next
spanners wrote:
Went to Morrisons in the van, it didn't break or anything!
Drove back feeling quite smug. 8-)
So the car isn't as worse as you described; great that it behaves like it should...
January 5th, 2013, 9:54 pm
MOT'd it :D
broke it :(
fixed it 8-)
broke it :x
left it :cry:
January 6th, 2013, 7:01 am
Still fitting the new adjusters to the drum backplate off the old Dyane. Every so often, I give it a few knocks with the hammer and the special tool as I walk past. The white one has now sat out on the road since before Christmas ... must get out theree and drive it at least around the block. It's in line for a steering rebuild when the beige one finally comes off the drive. I've also got three guitars to rebuild and a house which needs quite a bit of work. And a job.
January 6th, 2013, 12:20 pm
Took delivery of a freshly overhauled engine, fitted new shock absorbers, a pair of king pins and new drive shaft gaiters. Sent a gearbox off for overhaul. With thanks to Rick Pembro and his mobile workshop.
January 6th, 2013, 7:27 pm
This weeks task - service car, replace bulbs fuses and other things ive not bothered with,
Then get it mot'd.
I plan on parking the 106 up in the summer and using the 2cv daily. Rain or shine!
January 7th, 2013, 12:29 am
Gave it a once over- greased the kin pins, changed gearbox oil.
January 7th, 2013, 7:22 pm
Noticed rear offside indicator wasn't working. Tried to remove the light cover, but in doing so sheared one bolt and knackered the other's cross head. Eventually managed to get the cover off - only to discover that the indicator wasn't working because the connector (inside the boot) had been disconnected. Triggered a bad bout of tourettes! Rear light cover now held in place with very stylish length of heavy duty Gorilla tape.
January 7th, 2013, 7:39 pm
Haggis Muncher
Carefully dismantled, cleaned, refurbished and then re-assembled the fuel/charging gauge unit from the acad, only to realise that i probably should've taken a load of pictures and made a how-to :oops:
I do believe i have another hidden away in the depths of the garage if anyone would be interested in me doing one?
January 7th, 2013, 9:16 pm
Drove it to work (Cote d' Azur), first time it's moved in about a month.
January 8th, 2013, 1:45 am
Used it to pop down to Pershore to visit my mother in hospital. Had the hood fully open on the way there and back 8-)
January 8th, 2013, 2:50 am
