View unanswered posts | View active topics It is currently May 6th, 2026, 11:35 am
Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Engine problems - need ideas
Post Re: Engine problems - need ideas
New leads dear boy......
November 24th, 2012, 11:07 pm
Haggis Muncher
Replaced the HT leads about a month ago. Didn't make any difference... :/
November 24th, 2012, 11:22 pm
i had the same problem, replaced the ht leads with "expensive" ones, and it did that, replaced them again as advised but this time with cheaper ones, all is still well a year on!
November 25th, 2012, 12:19 am
Haggis Muncher
Might just give it a try! Although i plan on having 'van day' tomorrow, so i'll try the various other ideas first :)
Cheers folks - appreciate the help so far.
November 25th, 2012, 1:08 am
Haggis Muncher
Also BADLY need to crank up the front suspension. Four thoroughly dead shocks have left my poor suspension completely vulnerable to every bump on the roads, and the nose of the van has slowly been heading road-wards for months as the tie-rods unscrew themselves :lol:
November 25th, 2012, 1:14 am
Really? Tie rods unscrewing themselves? Not seen that before. I might suggest you delve a bit further into that one...
November 25th, 2012, 1:23 am
Haggis Muncher
I just figured it was something like that as the roads around where i used to work were AWFUL - I may be wrong lol.
I know my chassis is good, so what else could it be?
November 25th, 2012, 1:34 am
Haggis Muncher
Haha - I'm realising my a-series investigatory skills might need a bit of polishing up :lol:
November 25th, 2012, 1:36 am
Haggis Muncher
Progress! (of sorts)...
Went out to the van today, and started working my way through the suggestions. First on the cards was 'cleaning' the carb by sticking my hand over it.
Wasn't quite fast enough to stop it stalling out, but noticed that my hand was covered in oily gunk. poked a finger into the carb and gave it a wipe, only to find it was suddenly EVERYWHERE!
Figured that the oil breather might be involved somehow, so took the air filter out to have a look, only to find this... :shock:
A likely suspect, would you agree?
November 25th, 2012, 6:30 pm
looks like a lot of oil in there possibly ring /bore wear and or breather kaput ( recon ones available here)
foam can breakdown if there is spitting back through the carb (Ignition timing condensor probs and valve gaps)
November 25th, 2012, 6:41 pm
Users browsing this forum: No registered users and 131 guests
