View unanswered posts | View active topics It is currently March 20th, 2026, 4:28 pm
Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
 Which (if any) electronic ignition
Post Re: Which (if any) electronic ignition
By the way, there is no answer to 'what's best'. And this is one of those topics where everybody has an opinion and nobody agrees.
November 15th, 2012, 9:46 pm
I agree with Russ
November 15th, 2012, 9:53 pm
Had Dyane's with points, 123 and 1-2 spark. Must say never had problem with all 3 systems. The only thing I would say for electronic is the need not to remove the fan every time to do the points. Can I ask what is the problem with bump starting with electronic ignition??
November 15th, 2012, 9:55 pm
Jameswallace wrote:
Nelsthebass wrote:
Er James - sorry but most, nay, all modern cars run electronic ignition of some design or another and, unless they are fatally flawed, start a darned more reliably than a points equipped A series.....
I agree with russ
Mine always starts on points
What about when u jump start your car when 123 is fitted..?
Ipgo have you tested for that senario.?
Whats the point :lol: :lol: here???? ofcourse it will work, why wouldn't it....
I woulnd't try to start with 24volt (2 batteries in series) thats another story I think mine can do that but I don.t know for 123 and co.
Cranking it by hand is a challenge with 123 is told to me you can't do that. Dgnition you can crank by hand, mine too.....
inverse polarity of 123 and co. I dont know, mine does.
Take 1 pole of the batterie while engine running, I haven't tested yet so I don't know (at the moment) will test soon... 123 and co I don't know...
Mark 4x4 left the ignition key on for a whole weekend and started without problems at monday on 1-2-spark.
I know 1 thing for sure you can't do that on points.... because they have drained your batterie or are burned or coil has gone.
Another problem with points is that they overheat the coil anyway so youre coils brake down...
Well I think this is enough for now...
November 15th, 2012, 9:58 pm
Can your turbo car making its's full potential on points or 123?????
November 15th, 2012, 10:02 pm
most of the probs seem to be with the standard coil
i have d-nition and a yellow harley type coil but it was fitted befor i bought the car, the engine fires up immediately
November 15th, 2012, 10:04 pm
My coil is coming up to 25 yrs old and still going strong
November 15th, 2012, 10:06 pm
"Cranking it by hand is a challenge with 123 is told to me"
why cant a 2cv be cranked by hand if its fitted with 123 ipgo?
November 15th, 2012, 10:07 pm
Can i just wade in and say that i have had cars with points/condenser or electric ignition. Which do i prefer - points and condensor, purely because if something goes wrong i replace the bits very easily and cheaply (keep spares in the boot). If the electronic ignition gives up, your stuck (usually on a fast road) with no option but to call the AA.
November 15th, 2012, 10:10 pm
The coil is not the problem the ignitionsystem is. A black 2cv coil needs only 0.004 sec
yes 4 thousands of a sec current (at 12 volt) to make a decent spark... On points this time will be multiplyd 400 times or more (at idle) and this will go into the capacitor and/or heating (burning) up your coil....... so it will be destroyed........
The new generation of capacitors for 2cv are crap making it even worse...
Even 123 is giving to long current and some to less (123 for visa coil) running on 1 cilinder...
meaning to less dwelltime....
November 15th, 2012, 10:13 pm
