View unanswered posts | View active topics It is currently February 22nd, 2026, 6:27 am
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 my kingpin came out a bit
Post Re: my kingpin came out a bit
ayjay wrote:
ive found another arm with hub and good-ish kingpin, ill replace the knackered arm ;)
You'll be in trouble when Viking finds out ... ;)
October 5th, 2012, 7:11 pm
i think its the better way out of the problem rythem theif :D
i went to the shops today
blood- heck, the whole body/steering wheel shook at about 35mph :shock:
the eye in the arm must be really knackered
i,ll post tomorrow :D
October 5th, 2012, 11:09 pm
If I lived nearby, I would come around and hit your head with real fucked arm :mrgreen:
Why on earth reject a healthy arm when an oversized pin can fix the problem.
October 6th, 2012, 12:54 pm
i,ll change the arm then i,ll order an oversized k/p and repair the old arm ;)
do you supply o/size pins ?
October 6th, 2012, 1:07 pm
You can get 17.1 or 17.2 mm. How loose is the original pin? Can you push the pin through without too much force. If the pin slides through without any force, you need 17.2 mm. Best is to measure the hole with a plug gauge.
Most pins I fit are 17.1 mm
October 6th, 2012, 1:15 pm
cheers 2cv viking , i,ll check the pin/eye, in the old arm tomorrow, ive replaced the arm today, no probs at all(the replacement arm is complete with a good k/pin) :D
October 6th, 2012, 6:55 pm
