ayjay
 Re: Noise - manifold/carb?
apparently theyre prone to cracking james, the plate is there to reduce heat transfer to the carb- don,t forget to order 2 paper gaskets as well, they fit either side of the plate -use a smear of jointing compound on the faces there are 4 studs & they all need to be in place, if u only use 3 studs you,ll get an air leak
| September 14th, 2012, 12:29 pm |
Jonathan
Joined: January 1st, 2009, 7:37 pm Posts: 4713 Location: Disunited Kingdom
When fitting, don't over-tighten the nuts or you'll risk cracking the new one.
| September 14th, 2012, 12:31 pm |
james2cv
Joined: April 18th, 2009, 8:01 pm Posts: 947 Location: Paris/Manc
Ok cheers. This sounds like a simple question but can I replace the stud, or does it mean I have to put a whole new manifold on?
| September 14th, 2012, 12:40 pm |
Jonathan
I #think# it's a straight forward job, but don't quote me on that
| September 14th, 2012, 12:46 pm |
James, it's a stud, not a bolt and it will have unscrewed itself from the manifold, usually because late engines had no lock washers fitted to the 2 studs at the front of the carburettor. Add some poor maintenance to the mix... Refitting it should be straightforward, clean the threads and wind it back in, but make sure that you've got 4 lock washers to hand before starting to fit the new spacer block. ken james2cv wrote: Urgh found problem.... Huge chunk of plastic carb base missing.... Along with a sheared stud bolt being held nicely in place by the bottom of carb.... WTF.... Ok so I'll get a plastic thing ordered.... Will the carb be alright with just three bolts for a while though? I've got a spare manifold but going to uni a week tomorrow  Also... HOW THE HELL HAS THIS HAPPENED?
| September 14th, 2012, 2:00 pm |
J-dub
ken wrote: James, it's a stud, not a bolt and it will have unscrewed itself from the manifold, usually because late engines had no lock washers fitted to the 2 studs at the front of the carburettor. Add some poor maintenance to the mix... Refitting it should be straightforward, clean the threads and wind it back in, but make sure that you've got 4 lock washers to hand before starting to fit the new spacer block. ken james2cv wrote: Urgh found problem.... Huge chunk of plastic carb base missing.... Along with a sheared stud bolt being held nicely in place by the bottom of carb.... WTF.... Ok so I'll get a plastic thing ordered.... Will the carb be alright with just three bolts for a while though? I've got a spare manifold but going to uni a week tomorrow  Also... HOW THE HELL HAS THIS HAPPENED? Funnily enough ken, i was missing the front two nuts for about 6 months!!
| September 14th, 2012, 2:07 pm |
Devils Advocate
"Funnily enough ken, i was missing the front two nuts for about 6 months!!"
As from next Friday, our new puppy will be missing his...
| September 15th, 2012, 12:48 am |
Jonathan
Fronts or rears?
| September 15th, 2012, 12:58 am |
J-dub
Just realised how i said that!,,,,
| September 15th, 2012, 8:44 am |
lpgo
| September 15th, 2012, 9:31 am |
