View unanswered posts | View active topics It is currently May 2nd, 2026, 12:43 am
Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
 Noise - manifold/carb?
Post Re: Noise - manifold/carb?
apparently theyre prone to cracking james,
the plate is there to reduce heat transfer to the carb- don,t forget to order 2 paper gaskets as well, they fit either side of the plate -use a smear of jointing compound on the faces
there are 4 studs & they all need to be in place, if u only use 3 studs you,ll get an air leak
September 14th, 2012, 12:29 pm
When fitting, don't over-tighten the nuts or you'll risk cracking the new one.
September 14th, 2012, 12:31 pm
Ok cheers. This sounds like a simple question but can I replace the stud, or does it mean I have to put a whole new manifold on?
September 14th, 2012, 12:40 pm
I #think# it's a straight forward job, but don't quote me on that :lol:
September 14th, 2012, 12:46 pm
James,
it's a stud, not a bolt and it will have unscrewed itself from the manifold, usually because late engines had no lock washers fitted to the 2 studs at the front of the carburettor.
Add some poor maintenance to the mix... :(
Refitting it should be straightforward, clean the threads and wind it back in, but make sure that you've got 4 lock washers to hand before starting to fit the new spacer block.
james2cv wrote:
Urgh found problem.... Huge chunk of plastic carb base missing.... Along with a sheared stud bolt being held nicely in place by the bottom of carb.... WTF.... Ok so I'll get a plastic thing ordered.... Will the carb be alright with just three bolts for a while though? I've got a spare manifold but going to uni a week tomorrow :( Also... HOW THE HELL HAS THIS HAPPENED?
September 14th, 2012, 2:00 pm
ken wrote:
James,
Funnily enough ken, i was missing the front two nuts for about 6 months!!
September 14th, 2012, 2:07 pm
"Funnily enough ken, i was missing the front two nuts for about 6 months!!"
As from next Friday, our new puppy will be missing his...
September 15th, 2012, 12:48 am
Fronts or rears? :lol:
September 15th, 2012, 12:58 am
Just realised how i said that!,,,,
September 15th, 2012, 8:44 am
:oops: :oops: :oops: :oops: :oops:
September 15th, 2012, 9:31 am
Users browsing this forum: Google [Bot] and 121 guests
