View unanswered posts | View active topics It is currently June 19th, 2026, 7:15 pm
Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 2cv Mods and Improvements (totally subjective) ( . ) ( .)
Online
Post Re: 2cv Mods and Improvements (totally subjective) ( . ) ( .
Looking tidy.
April 14th, 2012, 1:14 pm
Love the (spoke)? wheels in the background, can you make a picture please :roll: :roll: My Dagonet dreams are playing up seeing them 8-) 8-) 8-)Image
April 14th, 2012, 10:29 pm
Here's a set of stainless wires for an Avion. No longer made. Not possible to buy them.
April 14th, 2012, 11:06 pm
Inspired by Joolz's steering rod end modification I have gone and made my own... I just hope it works as well!
I ordered the Rose Joint from a mob in India, price was cheap but shipping was excessive!
The original plan was to machine the ball off the end of the arm and cut a thread into the top, then use a reducer to bring it up from m8 (?) to m14... But instead I cut them off and welded a high tensile bolt on the end...
I realise that the profile may be to high and foul against the inside of the wheel but I can reduce the bolt and nut height if required or even lower the the rose joint on the shaft...
I remember some saying that Joolz's idea will inspire a a lot of bad imitations, so here is mine! :lol:
Fire away ;)
April 18th, 2012, 7:46 am
Online
@Harley,
I too have welded "critical" components, but have as yet it hasn't been on the road. ;)
April 18th, 2012, 9:42 am
There are spoked peugeot rims available on leboncoin that will fit the 2cv pcd
April 18th, 2012, 10:46 am
Pete,
but did those modifications involve welding any high strength bolts?
http://www.portlandbolt.com/faqs/weldin ... chor-bolts
Ken
subarupete wrote:
@Harley,
April 18th, 2012, 12:38 pm
Arms milled to reduce the rear boss by 8mm - note that the root of the steering arm itself is has not been machined, paint wasn't even damaged as the arm was held on the key during machining. Took maybe 5 minutes per side. There is now over than 12mm thread engagement - 20% more than the original 10mm.
April 18th, 2012, 1:55 pm
Online
@Ken :o ;)
No bolts... But these parts...
Rack Internals, but not the rack.
Steering Arm
April 18th, 2012, 2:39 pm
ken wrote:
Pete,
Ken
subarupete wrote:
@Harley,
Given that the bolt is now m14 where as the narrowest point on the original arm is 7mm or less AND that I laid enough weld to prevent the continental shift of Africa, I should hopefullyprobablypossiblymaybe be in the clear... :|
Nice link Ken, keep them coming.
April 18th, 2012, 3:53 pm
Users browsing this forum: No registered users and 175 guests
