View unanswered posts | View active topics It is currently March 18th, 2026, 5:40 am
Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
 France vs England
Post Re: France vs England
Geert wrote:
You did not mention the maximum price you want to pay for it. ;)
Not haha-ing you but Franze-boy asking 19 euros for a 2 euro seal.
February 6th, 2012, 2:53 pm
Viking,
I think you'll struggle to find a seal of that diameter for 2 Euros, more likely to be closer to 10 Euros? ;)
http://www.123pieceauto.com/citroen-vis ... tml?list=1
That link doesn't work too well, but put NF810 in the Recherche par référence window and you'll find a Payen seal listed as 10.47 Euros.
February 6th, 2012, 3:41 pm
Maybe you 'll get a discount :D
Or as the Franzose-boy would say : Rabat !
February 6th, 2012, 5:05 pm
Sean wrote:
if your getting a UK Argon mix you will need....
or similar
that esab looks like it only has 2 power settings might be worth checking what the minimum aperage is or you could be blowing holes in everything.
http://www.welding.org.uk/esabmanuals/Instruction%20Manuals/Origo%20Mag%20C140,%20C150,%20C170,%20C200,%20C250.pdf
35amps minimum might need a bit of practice to get used to it.
Next step. 10L of pure Argon arrived from the UK. Sean where do I buy the regulator. Another friend is roaming the UK at the moment and can bring it back
In advance many thanks
Viking
February 15th, 2012, 3:14 pm
Ah!
you dont want pure argon for welding steel you really need the Argon co2 mix
you need pure argon for aluminium and for Tig welding
If your friend is in one place long enough then weldquip will dispatch the next day "to site" ie somewhere other than the payees home adress - usually when your getting plant / materials delivered to the place you are working
For that bottle you need an argon mix valve - side entry
http://www.weldequip.com/argonmix-conversion-kit-se.htm
worth getting the one with the hose as that will be the next thing- ready to go with one of these
most big towns have a "Machine mart" where your mate can walk up to the counter and walk away with the thing.
http://www.machinemart.co.uk/shop/range/guid/628688F9-084E-41F1-87F3-ADE549DC71BB
remember to gat adapter hose at £15 ish
but the machine mart model is a cheap crappy affair.
February 15th, 2012, 4:02 pm
Well I'm stuck with this bottle as I can't replace it until empty. Do I need regulator for pure argon or mix?
Bugger my friend is leaving saturday but will ring straight away to find out if they can deliver latest friday or saturday morning.
Cheers
Viking
PS. Order done over the phone. Regulator is the same for pure or mixed argon.
February 15th, 2012, 5:03 pm
Missed that out welding a van
yes Wescol the better made reg and the "argon" is the male connector and does argon and argon mix
February 15th, 2012, 6:49 pm
Sorry don't get it :o
February 15th, 2012, 7:35 pm
I can pick a regulator up tomorrow if you need one.
February 15th, 2012, 8:29 pm
Missed that, (I) was out welding a van.....
must remember punctuation, must remember punctuation.
February 15th, 2012, 8:39 pm
