View unanswered posts | View active topics It is currently February 22nd, 2026, 6:54 am
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Chassis Replacement or no???
Post Re: Chassis Replacement or no???
Joolz,
always best to start at the beginning...
" I have a bit of corrosion on the bottom of the N/S front chassis. Its quite close to the front (Engine mounts and where all the weight is placed) "
As you've said, if there's corrosion in the chassis near the front or rear axles, or 'repair' patches evident on the underside, it's time to have a closer look.
Joolz wrote:
If the problem area is around where the front axle bolts on (and it usually is), then this area is under a lot of stress, and to repair it satisfactorily would need the bodyshell and axle removing, in which case you might as well replace it. Show us a good photo of the problem and we might be able to put your mind at rest, or tell you that it needs further investigation.
September 10th, 2011, 12:47 am
ken wrote:
Joolz,
:oops: Ah yes, you're quite right Ken, I was distracted/confused/led astray, by all the subsequent posts referring to rust under the bulkhead area.
If the rust is under the headlamp bar mount it's not nearly so drastic, and I'd say it was probably repairable. If jack's really lucky he may even find a scrapped chassis that's still solid in this area which could donate a section. A picture would still help with diagnosing how serious it is though.
September 10th, 2011, 1:10 am
Joolz,
I've replaced the engine bearer cross members on both an OE chassis and a Falcon chassis recently, probably the easiest part of a chassis to work on, tbh.
In addition to providing photographs, it would be handy if Jack did some tapping on the metalwork with a small hammer and reported on any areas which sounded 'crunchy' rather then metallic... :)
September 10th, 2011, 1:21 am
Hi Jack.Graham at the 2cv garage is a really nice guy.He did the welding on my D*lly.Why not give him a call?
I am sure he could help you.
September 10th, 2011, 7:44 am
I had an engine fall out of KEV, that ropey red spesh I had. The front crossmember snapped and I drove it about for a while with the rockerbox resting on what was left of the chassis.
September 10th, 2011, 7:37 pm
Jack,
Might be worth keeping an eye on this as it's in Liskeard...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ink:top:en
September 11th, 2011, 6:07 pm
