View unanswered posts | View active topics It is currently May 6th, 2026, 2:17 pm
Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
 Replacement sills
Post Re: Replacement sills
Hi 2CViking.
Who makes good sills in France.
As shipping from UK would be Expensive to the SW of France.
Regards Peter
September 8th, 2011, 1:26 pm
Peterj wrote:
Hi 2CViking.
Regards Peter
Nobody as I know. Cassis gets them from a supplier unknown to the public.
Ours are sold from Holland and most likely made in the east of Europe.
They are not easy to fit unless you have tried before. I have fitted many with very good result but a bit of a joggle. The spot welding is well done, metal are solid. The cheap sill without seat belt holes are a waste of time, very thin. Also seen welding spots letting go.
http://www.2cviking.eu/catalog/index.ph ... anguage=en
September 8th, 2011, 1:57 pm
Hi 2CViking.
Thanks for the info.
Regards Peterj
September 8th, 2011, 5:39 pm
Remember you can always make your own!
I didn't have the time or money to have some sent to me in Oz, so i took a section cut to a sheet metal place and had them fold them up, i had to source the correct diameter steel tube for them to fold the edge around then i welded them up myself. To fit them i cut the front end to length then placed it in position then shaped and tacked the back one into place.
LPGO has also made his own from a very simple technique that i wish i had thought of!
This way you can make them as strong or as weak as you like;)
September 9th, 2011, 3:55 am
Make your own sills if you can... Here is my old plans for it... use 0,8 or 1,0 mm sheet metal
www.2cvkeza.com
September 9th, 2011, 7:36 am
some good work there.wish i had time/skill to make own :)
September 10th, 2011, 3:02 pm
Users browsing this forum: No registered users and 102 guests
