View unanswered posts | View active topics It is currently July 16th, 2025, 12:32 pm
Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
 A new thread all about muffs.
Old Bloke
Post Re: A new thread all about muffs.
On the other hand.
The main problem is the variations in temperature in the UK. Whilst you can wake up to a frost in the morning [-3 ] by lunch time you can be at +12.
If the air flow on a 2CV was thermostatically controlled, the flow would be restricted when cold and wide open at the higher temperature. In effect people should set off with muff on and take it off later in the day. How many people do that.
My issue with a muff is that people fit and forget. It would therefore be much better not to fit a muff in the UK unless a sustained cold snap is forecast where day time temperatures remain less than +5 degrees.
Now known as 602
http://www.2CVTech.co.uk
November 28th, 2009, 7:44 pm
Paul,
I still don't understand what significance there may be in your choice of 5 C ( or even 12 C) since according to Citroen, the muff can be left on until ambient temperature reaches 15 C?
November 28th, 2009, 8:04 pm
Old Bloke
Just trying to indicate that the ambient temperature in the UK doesn't often lend itself to having the muff fitted. I have seen so many cars with the muff left on much longer than it should be and on days where the temperature has risen significantly.
I am not a big fan of using a muff unless it gets really cold.
Now known as 602
November 28th, 2009, 8:10 pm
Paul,
yes, it's a balmy 4 Centigrade here at present, with more of the same to come. :roll:
< http://www.metoffice.gov.uk/weather/uk/ ... _temp.html >
November 28th, 2009, 8:35 pm
Old Bloke
Enjoy.... is it raining too?
It's quite horrible here too Ken. Staying in with a bottle of Bordeaux tonight.
P
Now known as 602
November 28th, 2009, 8:51 pm
...since you mention it... The muff's almost always on when I go to work a 7 in the morning, and depending on the temperature when I come home in the evening, I either leave it on or stuff it in the car. It's not exactly difficult to take on or off!
November 28th, 2009, 9:30 pm
Old Bloke
That's exactly the right way, but not many people do that. :|
Now known as 602
November 28th, 2009, 9:51 pm
I have a stick-on thermometer on the inside of my windscreen. It's the sort of thing you're supposed to use on greenhouse glass. Tells me exactly what temperature it is first thing when I get to the car. No use if the sun's shining on it or after a while with the heater on, but helps with the initial decision.
1981 Jade green Dyane :-)
November 29th, 2009, 9:14 pm
Jisses christ guy's, this isn't rocket science :lol:
Winter is mufftime, take it off in summer.
If the 2CV can handle temps in sahara without a muff, it can handle the english summer with a muff, don't you think? They dont completely block the airflow.
Now, let's see more of them muff-pictures...... :mrgreen:
Vennlig hilsen, Eirik
And a Heinemann Z412 -80
November 29th, 2009, 9:41 pm
ken wrote:
Hmmm,
I'm sure there was another thread on this topic, but that seems to have disappeared when this one was opened... :?:
we started on ginger blokes jean claude (damn van) topic and decided to start the new topic here
Low and Loud!
November 29th, 2009, 11:24 pm
Users browsing this forum: No registered users and 73 guests
