View unanswered posts | View active topics It is currently April 28th, 2026, 12:07 am
Reply to topic  [ 1048 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54, 55, 56 ... 105  Next
 Make Your Own ....2CV.... 4x4
Front Suspension.
Pivot point is the same radius and the coil spring pivot.
As the arm moves the strut (bottom mount point) radius stays the same, only the angle of the strut alters.
The struts are designed to lift a C5 @ 1460 Kg
Spheres come in a range of pressures, 32Bar to 63Bar so I can set how soft/hard the suspension is set, also LHM spheres fit, these can be re-gassed to any pressure you require.
August 9th, 2015, 12:44 pm
subarupete wrote:
Front Suspension.
The attachment Screen Shot 2015-06-25 at 16.32.29.jpg is no longer available
With the spring setup as on the picture, the suspension works more progressive, as the radius gets larger when the wheel moves up, a standard 2cv suspension is also quite progressive because of this sort of setup, unless it's lowered to much.
August 9th, 2015, 5:03 pm
This is what I have planned....
Rear.
Working with Soft Ride and adequate damping...
Front.
TBA
August 9th, 2015, 6:37 pm
Front Suspension.
FAIL......
https://youtu.be/KdAkEG8BsS4
Better.
https://youtu.be/h7Iif0W_AI4
August 12th, 2015, 11:27 am
@Lpgo.
You are half-correct, had to move my pivot point.
It now positioned on the down side of where the steering tie-rod crosses the arm.
Of course.....the best position is where the steering Tie-Rod directly crosses the arm!
Need to redo the other arm, but have no more laser cut brackets :(
August 12th, 2015, 6:14 pm
Your welcome....
August 12th, 2015, 6:51 pm
Front seems to work...
See https://youtu.be/OK-BELUi3bM
August 15th, 2015, 5:04 pm
Looking great sofar. I think you are going to notice a major diffrence (for the better) going off-road... I like it alot
August 15th, 2015, 5:40 pm
Now have the capability to get REALLY stuck!!
August 15th, 2015, 5:54 pm
Or to lift yourself out of trouble........ ;) ;)
August 15th, 2015, 6:18 pm
