View unanswered posts | View active topics It is currently February 21st, 2026, 11:55 am
Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Sticking Gearbox
Post Re: Sticking Gearbox
Will upload findings as I go.
Here 1st/reverse hub buggered.
Some minor damage to the splines on the 2nd/3rd sliding pinion (sliding inside 1st/reverse hub)
Entire box is full of tiny metal chips. All needs cleaning out. You can see small chips sticking to the casing in the oil. Some bearings have metal chips in them
April 15th, 2013, 2:00 pm
oh dear....... I am selling that A Frame and buying a trailer. :oops: :oops:
April 15th, 2013, 4:24 pm
i wouldnt have thought an a frame could do that much damage… especially if it wasnt in gear
edit: sorry for copying a few people :oops:
April 15th, 2013, 5:54 pm
When I took the lid off and rolled the car back and forth, there was a lot of moving gears. So I suppose it only take a bump or so on the road and the shifter might engage slightly, chip[ away at something and fall back.
And as it did not have much oil in either - I don't think I want to take that risk. So either I will drive it or trailer it.
Found some nice trailers (small and light) that I will save up for later in the year.
April 15th, 2013, 6:01 pm
Nothing to report on the input shaft. The oil leak reaching the clutch is not from here. The scroll is good but not sure if the bearing is obstructing the air flow. Maybe the box was overfilled at some stage.
Except last person didn't lock the nut. Should have been replaced
Interesting? Hub is 4 holes, gear box casing 6 holes :roll: Not that is matters unless the hubs were swapped without setting the crown bearing preload and the back-lash.
I wonder why?
April 15th, 2013, 7:26 pm
I suppose a lot can happen in 56 years. I didn't notice the 6 stud holes though.
The only thing I can think of is that this would have had a centrifugal clutch... or that is what people tell me.
April 15th, 2013, 10:19 pm
Wouldn't have thought so, going down hill in a loaded van with a centifugal clutch may have got "interesting" and that input shaft isn't one for a centrifuge.
April 16th, 2013, 10:52 am
Using A frame has no bearing (no pun intended) on your situation - The gearbox works more when you drive it..
April 16th, 2013, 11:17 am
But at 110kph...
I think it was the fact it had crappy oil. But now it will always be on my mind :?
But you are right - there must have been some issue as the top had recently been off.
April 16th, 2013, 12:33 pm
Generally gearboxes are not ruined by speed - Torque is the killer. So free wheeling at 110 kph should be fine. :)
April 16th, 2013, 12:47 pm
Users browsing this forum: Bing [Bot] and 104 guests
