View unanswered posts | View active topics It is currently May 1st, 2026, 8:21 pm
 Prob. with ignition/alternator/fuel gauge/indicator circuit
Post Prob. with ignition/alternator/fuel gauge/indicator circuit
Hi there. Can anyone help? My Dad's doing an engine change on a local 2cv (late model, two fuse boxes), and it turns over but won't start. We've traced it to a problem with the main ignition circuit (blue wire on the top fuse box) - there's no power there at all to this fuse. I can only assume that there's a break in the loom between the ignition switch and the fuse box, but before we remove all the loom tape/speedo, can anybody suggest anything else? We've cleaned all contacts and put a paperclip across the wires on the back of the igntion switch, to elimiate the switch itself.
It would appear that the "dead" wire is the one on the passenger side of the car.
Thanks
April 14th, 2013, 11:23 am
Post Re: Prob. with ignition/alternator/fuel gauge/indicator circ
What was the score before the engine change? I find it hard to see how an engine swap can suddenly cause a problem like that inside the car, way away from where you were working. And coincidence seems unlikely.
April 14th, 2013, 11:29 am
Thanks
that's not the problem that's one of the the consequences
Is there 12is volts to the starter switch and back out? - the coil live splices off before the fuse so it should run even if the fuse is out. black is supply 12 v red is starter solenoid and Mauve is the rest of the car including ignition
you did put the terminals back on the corect pins? did you do up all the blue wires on alternator starter and battery?
electrical stuff just needs carefull and methodical investigation - start at the fuse and work back down the loom looking for live.
April 14th, 2013, 12:12 pm
Jono,
is 12v reaching the coil?
If not, a quick way to bypass the original wiring is to run a wire direct from the battery to the coil, which would check if there's a problem with whichever ignition system is fitted.
If that works, whatever the problem is with the loom could be sorted at leisure...
April 14th, 2013, 1:26 pm
It worked, but the engine didn't as the owner had been driving it around without any oil in!
Thanks for the answers, guys. I'll pass them onto my Dad.
April 14th, 2013, 6:10 pm
Just a wild thought, the earth from the battery is on properly isn't it?
April 14th, 2013, 6:27 pm
Is there a set of points in the 'new' engine. Is the coil connected the right way round?
April 14th, 2013, 6:53 pm
Bob,
2CV (and other double-ended) coils work just as well either way round.
In fact, reversing the polarity of the low tension connections will equalise erosion of the plug electrodes resulting from the HT spark(s). :roll:
April 14th, 2013, 9:00 pm
ken wrote:
Bob,
In fact, reversing the polarity of the neutron flow will equalise erosion of the plug electrodes resulting from the HT spark(s). :roll:
http://www.youtube.com/watch?v=yLD03bU5R5M
Sorry Ken :lol:
April 15th, 2013, 12:24 am
Ditto... ;)
http://www.youtube.com/watch?v=jyaLZHiJJnE
April 15th, 2013, 1:15 am
Users browsing this forum: No registered users and 73 guests
