View unanswered posts | View active topics It is currently May 2nd, 2026, 3:17 am
 Aluminium casting repair kit
Post Aluminium casting repair kit
Nicked from a chap on the Series 2 Landy forum. Potentially useful for anyone with a damaged crankcase to repair, such as me.
http://www.lasertools.co.uk/item.aspx?code=4707
November 7th, 2012, 11:11 am
Post Re: Aluminium casting repair kit
Link leads nowhere. :) Working now.
John Jordan
November 7th, 2012, 11:48 am
Useful item
ps
link works here
November 7th, 2012, 12:33 pm
I've used this stuff; it is very good but a lot trickier to do than the video makes it seem.
There's no flux needed but thorough tinning is vital and the wire brush must be stainless. Basically you get the parent metal surface hot enough to melt the stick and after coating scrub through with the brush; this breaks the surface oxidation and allows the tinning process to work.
It won't bond to steel hence making a new thread with a steel bolt does work, tinning is very difficult inside a hole but a scriber can be used effectively.
November 7th, 2012, 1:51 pm
I've used something similar before, with a bit more practice I think it could be quite useful. Google 'techno weld' for more information.
November 7th, 2012, 10:20 pm
Not sure I understand, how is this better than welding?
November 7th, 2012, 10:31 pm
You don't need a "welding machine" just a torch
November 7th, 2012, 10:59 pm
Simple, you can pick up a kit for £40, and do it at home with a blowlamp.
You can also 'weld'(join) really thin stuff with no discernible talent, as you're not melting the work piece. And you can join dissimilar metals.
November 7th, 2012, 11:04 pm
I remain sceptical. Joining dissimilar metals is an advantage mind you.
November 7th, 2012, 11:19 pm
Obviously there are plenty of ways that welding is better too. They're different, both have advantages in different applications.
November 7th, 2012, 11:23 pm
Users browsing this forum: No registered users and 116 guests
