View unanswered posts | View active topics It is currently September 10th, 2025, 10:48 am
Reply to topic  [ 63 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 reniflard
Post Re: reniflard
Sean,
I'd doubt that there would be anything like that amount of gas being moved through the breather, as the effective 'compression ratio' of the crankcase is very low. ;)
If you hook up a pressure/vacuum gauge to the dipstick tube with the engine ticking over, the needle oscillates between about +2 psi and -1 psi, which fits with crankcase vacuum, with a good breather fitted, being less than 1 psi.
In fact, 60mm water gauge is less than 0.1 psi...
Can anyone offer a convincing explanation as to why -0.1 psi under the pistons could have any measurable effect on the power output of an engine which has a BMEP around 125 psi?
( BMEP is the average pressure over a cycle in the combustion chamber of an engine. )
How it can improve starting is something else which escapes me. :roll:
Sean wrote:
Taskos wrote:
Simply blowing air by mouth feels like there is no resistance either side.
they never do even a good one. as Harley calculated in another thread it will pump 9 000 litres of air every minute at 6krpm, thats what sort of volumes of air it needs to put up with. as a man you have about 4l expelled air when you really go for it trying to replicate the 2cv engine will result in a light head very quickly.
May 5th, 2012, 1:19 pm
Post Re: reniflard
:lol: i was just trying to save Taskos from hyperventilating
there is a displacement by the boxer set up what the breather needs to do is vent any excess blowby gasses via the carb without letting the pressure fluctuations mess with the carburation- No?
all i know is that good breather = clean drive.
When David got his long tool out and did the manomiter tests on our cars at reg day the blue one had a positive engine however it always started, leaked very little and was a rather strong engine. it was still going strong 9 yrs later on the way to Most where it kept up with Vick and Dot at 70mph mixing it with the nuts Belgian traffic
May 5th, 2012, 2:34 pm
Post Re: reniflard
I believe that the vaccum was mainlydesigned for avoiding oil leakages on old/neglected engines.
BUT...
Theoreticaly...
At the issue of power losses, I think that if the system was airtight then the same underpressure would be overpressure depenging on stroke direction.
But if we take into account the gases escaping from the piston rings we may have a undessired and substantive possitive pressure.
In practice...
I find it harder to climb my local hill with a malfuncioning reniflard than a new one.
I've Been Wrong Before.
May 6th, 2012, 11:07 am
Post Re: reniflard
Sean wrote:
then folding it all back over gently going round and round moving it just a tiny bit at a time the joint is good and oil tight
http://www.youtube.com/watch?v=8YlEpI00ouU :D
May 13th, 2012, 9:12 am
Post Re: reniflard
ken wrote:
banjo,
in the absence of 'before and after' test results, guess I'm going to 'buy and try' one of these things.
I don't hold out much hope though, as a valve designed for use with a liquid doesn't usually function all that well with a gas, particularly if it's required to operate at a frequency approaching 100 Hertz.
I'm sure that someone posted about a similar check valve on another forum, that one seemed to work at tickover but not at higher rpm where it's needed most...
( p.s. Anyone else recognise the 'new breather' pictured on this BMW airhead site?
http://www.bmwscotter.org/procedures/oi ... ervice.htm ;) )
The BMW breather is the type fitted to the /5/6/7 boxers if I recall correct the reed valve modification was sold by Harman who did loads of stuff back in the day,they no longer trade.
May 18th, 2012, 7:22 pm
Post Re: reniflard
Is the Visa reniflard the same as the 2CV one? If not, are they somehow compatible?
Wish you all a great weekend. ;)
May 19th, 2012, 11:22 am
Post Re: reniflard
Ι would like to report that my plumbers one way valve didn't last for 1.000km.
The underpressure was 5cm at idling but zero to 3.000rpm.
So I've replaced the reniflard with a refurbished one according to Sean instructions.
Now it's 5-10 cm all the way.
October 23rd, 2012, 3:49 pm
Post Re: reniflard
The shower valve I fitted is still functioning even after several flat out trips to France and back,I don't seem to have as much oil loss/use so I guess it's okay.I would still like to rebuild the reniflard,just need to obtain a duff one to work on. Sean's method sounds a good route to follow.
October 24th, 2012, 4:12 pm
Post Re: reniflard
How many would you like?
October 24th, 2012, 5:27 pm
Post Re: reniflard
I'm going to do a decent pictorial thread showing how to rebuild one, I just haven't had the time at work to do it.
October 24th, 2012, 8:24 pm
Users browsing this forum: No registered users and 305 guests
