View unanswered posts | View active topics It is currently May 2nd, 2026, 1:55 am
 towbar wiring ?
Post towbar wiring ?
Hi,fitted and wired in my towbar socket,all works fine,just need a warning device now to tell me when trailer indicators are working,(law now ive just been told)either a buzzer or dash warning light,dont want a buzzer anyone tell me how to wire up a warning lamp in a 2cv please :?: ;)
October 7th, 2012, 12:10 am
Post Re: towbar wiring ?
my 2cv has a warning sounder, it came with instructions and is simple to wire it goes at the rear of the car inside the boot, the trouble is-it won,t work!
nor does my brothers :(
October 7th, 2012, 5:48 pm
Same here,previous car had a beeper,only worked when it felt like it,then it got on your nerves,hence why i want a flashing light :mrgreen:
October 7th, 2012, 10:27 pm
we just hitch up and have a look- see--
if the trailer light are working at the outset alls good
i can,t imagine a copper testing a warning buzzer, after all theyre not the sharpest knives in the draw :)
October 7th, 2012, 11:14 pm
I wired a buzzer into the 106, really easy to do if you read te easily mid understood instructions
First thing I did wrong was to wire it in parrelal instead of 'inline' there's 6 wires iirc.. 2 per indicator and earth and 12v..? Maybe only 5
Anyway the indicator wiring should pass trough the device via the appropriate wire, the idea is when there's load being drawn through the circuit by a trailer board being present it should beep. It took me a few attempts to get it right as its easily mis understood. I wired it parallel as it said 'wire this to pin x and this to pin x and this to wire x and this to wire x. To me I thought we'll the wire goes there anyway. Do it parrelal but I was wrong
October 8th, 2012, 8:34 am
Thanks for all replies,get this sorted for the weekend :)
October 8th, 2012, 9:11 pm
If u don't need it don't bother with it, there doesn't seem anything in the MOT that says u need one....!!
Dyane 12 1976 (ish)
October 8th, 2012, 10:12 pm
Matt. Maybe read the mot guide again. It is neccasary to have a warning light or sound when the trailer board is connected to indicate the indicators are working
October 8th, 2012, 11:54 pm
I'm surprised James, I don't remember it being the case in the past, and it's unusual for things to be applied retrospectively. Have you got a link to the appropriate paragraph in the testers manual?
October 9th, 2012, 12:52 am
Sorry James, I'm sure u r incorrect as its state under section 1.9 sub section 3 of the MOT inspection guide 2012 that the only electrical thing tested ref towbars is...... See below
3. On vehicles fitted with a towbar, check the condition and security of the trailer electrical socket.
Note: This check applies to both 7 pin (12N) and 13 pin electrical sockets.
4. On vehicles fitted with a trailer 13 pin Euro- socket, use an approved device to check that the socket is wired to correctly operate the trailer:
trailer 13 pin Euro-socket not operating the
 Position lamps
 Stop lamps
 Direction indicators
 Rear fog lamp
Sorry no mention of any lights or buzzers!!
As joolz says above have you any proof to back it up...
And I'll find out next month when I take the Laguna for mot as I recently fitted a towbar to it and got the local auto electricians to wire it up and there isn't a warning light or buzzer fitted to mind....
Dyane 12 1976 (ish)
October 9th, 2012, 1:19 am
Users browsing this forum: No registered users and 93 guests
