View unanswered posts | View active topics It is currently February 21st, 2026, 8:10 pm
Reply to topic  [ 6 posts ]
 Fan Extractor Tool
Post Fan Extractor Tool
I have always been frustrated by the clumsy method of extracting the fan off the taper. Does anyone know of a practical tool for sale that removes the fan without risking damaging it?
Cheers, thanks
October 7th, 2012, 12:54 pm
Post Re: Fan Extractor Tool
Part number 1100 on link
http://www.mcda.com/catalogue/show_cat. ... hicule=dy6
I use a 3/8 extension bar and move it sideways - same job and 57 euros cheaper
October 7th, 2012, 1:07 pm
Works well no hammering :o
October 7th, 2012, 1:18 pm
I seem to remember it's possible to swap the bolt for one with a socket head and then fit a collar that retains it in place. As the bolt is undone it presses against the underside of the collar and forces the fan off. Hope that makes some sense, perhaps someone else can remember where I saw it, was it Viking? It is a more elegant solution, but personally I've never had a problem using a piece of close fitting bar, and hitting it sideways with a hammer.
edit. Viking just beat me to it, but I was right.
October 7th, 2012, 1:26 pm
I always use a dab of neverseez and works as by the book.
Remember to check the welding seam.
I've Been Wrong Before.
October 7th, 2012, 7:04 pm
Just put a suitable sized socket in with an extension bar and jiggle the car up and down does the trick....
October 7th, 2012, 7:31 pm
