View unanswered posts | View active topics It is currently May 6th, 2026, 11:38 am
Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 my kingpin came out a bit
Post my kingpin came out a bit
i replaced the pins,& bushes and the welch cap,--then it came out and disapeared
the pin worked its way upwards till it came into contact with the
outer drive-shaft edge this caused a steering "wobble"
eeeee, the wonders of 2cv-ing :D
ive fixed it now(probably)
October 4th, 2012, 11:19 pm
Post Re: my kingpin came out a bit
Surely with the grade nipple fitted it can't move?
October 5th, 2012, 8:21 am
Ayjay if your king pin came out there's something really wrong. I'd suggest you change the arm as the eye at the end must be really worn to let a KP come loose and as it 'worked its way out' probably only enlarged the hole.
October 5th, 2012, 8:52 am
And JDub, the grease nipple doesn't do anything. There's nothing 'holding' the KP in - its designed as a tight fit between the arm and the hub so friction holds it in place. It shouldn't be touching the screw cover at the bottom or the welch plug at the top.
October 5th, 2012, 8:54 am
Check the thrush washers.
I've Been Wrong Before.
October 5th, 2012, 12:06 pm
Or fit oversized king pin.
October 5th, 2012, 12:17 pm
thanks guys ill check it properly , its strange why the k/p moved as it was a tight fit in the arm when i renewed it :?:
i did check the gap and use the correct shims taskos
but there is now a bit of play in the k/pin so i suspect the eye is worn :cry:
i,ll see if i can get an oversize k/p, altho the hole in the eye on the arm might be a bit oval?
October 5th, 2012, 2:03 pm
Viking (above) knows about, and suplies, over sized king pins, ask him.
October 5th, 2012, 3:28 pm
or if you have access to a welder ;)
October 5th, 2012, 6:02 pm
ive found another arm with hub and good-ish kingpin, ill replace the knackered arm ;)
October 5th, 2012, 6:48 pm
Users browsing this forum: No registered users and 130 guests
