banjo
Joined: June 5th, 2009, 9:17 am Posts: 747 Location: Staffs & France
 Re: Oil Leak from camshaft
Has anyone tried using a piece cut from silicon cookware as a replacement for the valve?
| August 28th, 2012, 11:34 pm |
See preceding post? banjo wrote: Has anyone tried using a piece cut from silicon cookware as a replacement for the valve?
| August 28th, 2012, 11:45 pm |
banjo
ken wrote: See preceding post? banjo wrote: Has anyone tried using a piece cut from silicon cookware as a replacement for the valve?  Ahh the same type of material then I see,maybe holes in the bake ware might not be such a good plan
| August 29th, 2012, 11:33 am |
the silicone bakewear makes a rather good valve however im not so sure about the longevity as it is affected by unleaded petrol
| August 29th, 2012, 5:34 pm |
ChrisW
Joined: February 21st, 2012, 9:01 pm Posts: 1136 Location: Avranches, Sud Manche, France
[quote="Sean"]those reed valve ones suffer corrosion from the condensation in them , the steel lump the carbon reed and the stainless keeper plate all conspire to rot the reed I will keep an eye on the corrosion - but now I can see what is going on with normal one it is all hidden. All oil leaks gone.................. !!
| August 29th, 2012, 7:40 pm |
Users browsing this forum: No registered users and 124 guests |
