View unanswered posts | View active topics It is currently May 6th, 2026, 10:49 am
Reply to topic  [ 5 posts ]
 Which way up do AVO dampers go?
Post Which way up do AVO dampers go?
I got no instructions with them, and there's no obvious markings on them other than some scrapes which i assume must've been on the underside, but anybody got any idea which way is up and which way round they're meant to go? I followed several sunday drivers home and couldn't really see if it was any different but I#m guessing if I've got the buggers on upside down they're not going to work correctly...
August 23rd, 2012, 12:08 am
Post Re: Which way up do AVO dampers go?
either way up as you want the ajuster wheel outwards, bodies to the chassis IIRC
( orientation in the bin is unimportant tho, the new alloy ones dont like shock load in tension)
August 23rd, 2012, 12:06 pm
Got them like this:
SV102246 by tomduckpower, on Flickr
August 23rd, 2012, 2:34 pm
Cheers. These aren't alloy they're steel, I only asked as mine wouldn't fit with he rubber cover end towards the front on the front end, and I wondered if I needed to modify the mounting plate. I've put them on and can't really tell a difference, except they're bigger and hit the ground more, and they look cool hanging under the car. the old ones were so stiff I couldn't move them by hand at all, I assume they're bent or something. Ah well.
August 23rd, 2012, 6:57 pm
They are the steel ones yes.
IIRC mine only fit this way, the other way round and the body would hit the mounting plate..
Just checked on 2cv.nl ans IRC ;)..
These are also steel ones, mounted the same way as mine..
http://link.marktplaats.nl/586357762
August 24th, 2012, 12:32 pm
Users browsing this forum: No registered users and 99 guests
