View unanswered posts | View active topics It is currently June 19th, 2026, 7:16 pm
Reply to topic  [ 4 posts ]
 steering rod ends
Post steering rod ends
hi all, another question if you don,t mind--i,ve reconditioned the inside of my outer steering rod ends
ive fitted new arm on one side as the ball was oval and worn out and new springs and cups both sides,plus new rubber shrouds-- the new caps have the inbuilt grease nipples.
--the steering seems a bit stiff though when driving, :(
how tight should the castellated /threaded cap be done up ? i have the correct socket to do the job btw
should i do the caps up as far as they will go then back them off a bit? if so how much?
thanks fellas :D
June 24th, 2012, 9:02 pm
Post Re: steering rod ends
I think it is 1/6th. of a turn back from fully tight, not 1/16th. as in Haynes.
John Jordan
June 24th, 2012, 9:43 pm
yup 1/6th of a turn
June 24th, 2012, 11:02 pm
thanks fellas ill check it today
June 25th, 2012, 11:53 am
Users browsing this forum: No registered users and 175 guests
