View unanswered posts | View active topics It is currently February 21st, 2026, 11:18 pm
 Steering Rack overhaul
Post Re: Steering Rack overhaul
Planning to tackle this job at registers weekend.. hopefully plenty of spares and a supply of willing helpers / advisers.
June 5th, 2012, 4:40 pm
Isn't there a special tool for removing the arms and then the bearings?
I've Been Wrong Before.
June 5th, 2012, 7:34 pm
You can buy a special tool but I've never needed it.
June 5th, 2012, 7:53 pm
rumble i bring the tool for the track rod ends
June 5th, 2012, 9:40 pm
Nice one Simon. Been reading up and am wondering about the pinion bearing... is it wise to replace this and is a special tool needed to remove it?
June 6th, 2012, 8:44 am
The pinion bearing is acctually part of the pinion and shaft.It is not replacable on its own.If the seal carrier/nut has two slots in it then you will need the tool to remove/re-fit it.The latest carriers have a nut type head on them,so if you have one of those you can just use a spanner.
June 6th, 2012, 9:06 am
Rumble,check out my van thread,"Dave411's AK 350",there are some pics on there from when I did the rack on my van.
June 6th, 2012, 9:19 am
viewtopic.php?f=5&t=3671&start=10
June 6th, 2012, 10:05 am
Wow! That's a comprehensive overhaul! The pictures are incredibly informative... thanks a lot for the link.
Is the welch plug reusable after it's knocked out btw?
I see that Ecas stock two types of pinion... 7 or 8 teeth. How do you tell which type is fitted to your car?
Mines a 77/78ish formerly 2CV4 and lhd. Does that provide a clue?
I'll have a look at J's pinion locking nut, but judging by age I imagine it'll be the one needing the special tool. So anyone going to registers who might be able to bring one along?
June 7th, 2012, 9:55 pm
I've got all the tools Aidan.
Don't know if I'll make registers as we'll have the kids that weekend but, I'm sure I can get the tools to you somehow.
June 13th, 2012, 7:44 pm
Users browsing this forum: No registered users and 110 guests
