Rumble602
Joined: January 26th, 2009, 10:16 pm Posts: 1074 Location: Derbyshire
 Steering Rack overhaul
I'm considering overhauling my steering rack this summer as it's starting to feel notchy... especially when on a long straight run such as motorways.
What level of technical ability will I be having to summon from the depths, and what special tools will I need? I
Is it worth stumping up for a recon rack to save myself undue pain?
Cheers,
Aidan
| June 4th, 2012, 10:58 am |
dave 411
Joined: August 19th, 2010, 10:44 pm Posts: 1815 Location: Cardiff
 Re: Steering Rack overhaul
It is a relatively easy job when its out of the axle.I overhauled the rack on my van,but the axle was out anyway.You may need a special tool to remove the pinion shaft,the seal is housed in a slotted housing(unless its been replaced with one with a nut on) and this needs to be unscrewed to get the pinion and bearing out.Once thats done,the rest is easy. You can take the axle off the car easily enough,dont know about taking the rack off with the axle in situ,but I am going to refurb an old rack and replace the one on my D*lly some time soon,so I will no doubt find out. You can buy a kit from Ecas to overhaul the rack.
_________________ [img]http://i1207.photobucket.com/albums/bb480/alastairsmith999/dave411-5.png[/im g]Horizontally Opposed
| June 4th, 2012, 11:20 am |
subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
May also need tool to remove track-rod's from rack. This tool from ECAS is made to fit. http://www.ecas2cvparts.co.uk/track-rem ... -1849.html Other tools may damage the ball-pins in the rack. For me most times its the pinion bearing that has failed Have a go, a recon rack is £220 + shipping for heavy item or your time + parts approx £70.
| June 4th, 2012, 11:40 am |
dave 411
Oh,and speak to Scooby Pete about fitting gease nipples,hes good at it
| June 4th, 2012, 11:55 am |
subarupete
@Dave ,you really must read through your posts before hitting the submit button
| June 4th, 2012, 12:05 pm |
dave 411
Whoops,sorry,hes crap at it
| June 4th, 2012, 12:14 pm |
Neil
| June 4th, 2012, 4:15 pm |
Rumble602
Cheers for the advice... i do have another question. is the rack serviceable in situ, or does it have to come out of the car? I'll have a punt on that rack... cheers Neil.
| June 4th, 2012, 4:25 pm |
ChrisW
Joined: February 21st, 2012, 9:01 pm Posts: 1136 Location: Avranches, Sud Manche, France
You have to take the rack out of the car, quite easy to do. 1/2 day to remove, repair and refit.
| June 4th, 2012, 4:37 pm |
Rumble602
I put a bid on that rack - although it's rhd and I'm lhd. Might be useful for spares at least. Are the internals interchangeable lhd/rhd?
| June 5th, 2012, 4:12 pm |
Users browsing this forum: No registered users and 105 guests |
