View unanswered posts | View active topics It is currently May 2nd, 2026, 7:48 am
 Nasty noise coming from rear arm
Post Nasty noise coming from rear arm
Can't stand it any longer... there's a horrible chafing/rubbing sound coming from my left rear suspension arm. Well that area anyway. I've had a look underneath but there's nowt obvious. All knife edges/axle bolts have recently been greased so I'm guessing its non of them. Anything more than a tiny bump and the noise will be there. When you bounce it up and down with hands on rear wing, its as if you can feel it, so guessing its something to do with bodywork catching or rubbing against something? Can't seem to find it though. Anywhere I should be looking where there isn't a lot of clearence? I get so wound up with it I think I'll end up crashing into a tree in anger soon. Any advice?
Cheers
May 12th, 2012, 6:27 pm
Post Re: Nasty noise coming from rear arm
Aim for a small one. A small shrub or something.
May 12th, 2012, 6:41 pm
arm bearing collapse
wheel bearing
brake shoe friction material off and catching the drum
May 12th, 2012, 6:47 pm
wheel bearing
Joy of joys. Thanks.
May 12th, 2012, 6:52 pm
Also check that rear shocker hasn't snapped off chassis mount point as it did on our Dudley......
May 12th, 2012, 7:22 pm
Have you checked the suspension spring canister?
Give it some 200ml of veg oil.
I've Been Wrong Before.
May 14th, 2012, 8:45 am
+1
I had the same story one year ago
May 14th, 2012, 9:09 am
What they said^ dry canister, a quick ,easy job and a bonus if that's all it is.
May 14th, 2012, 10:53 am
Cheers for the advice, although doubt its the spring can. I do veggie oil em regularly and its coming more from the back I think. Have a feeling it'll be one of the things Sean suggested, probably arm bearing. Ima jack it up this weekend and check it doesn't waggle or anything. Anything else I should be looking for to narrow it down?
May 14th, 2012, 11:35 pm
Veggie oil regularly?
Do you put it in and rotate the cans covering the spring ?
May 15th, 2012, 8:07 am
