View unanswered posts | View active topics It is currently May 6th, 2026, 11:29 am
Reply to topic  [ 28 posts ]  Go to page Previous  1, 2, 3  Next
 M4 Oil pipes
Post Re: M4 Oil pipes
Sweeeeeet :D Are M4 ones the same as 425 feed pipes?
March 25th, 2012, 11:05 pm
do the pipes run from the oil cooler to the heads?
have you got a set for me to copy?
March 26th, 2012, 8:08 am
I can nab a set off my spare 425 if you want?
March 26th, 2012, 8:10 am
cool !
PM sent
March 26th, 2012, 9:10 am
Russ there's a spare set of M4 ones in the barn on my spare M4 if you want to do a quick comparison.
They say M4s are big bore 425s (I'd like to compare the innards). Certainly the barrels are the same, just bored out for the 602, so if the heads are of a a similar physical size I'd have though that the pipes would be similar length?
I guess we shall see...
March 26th, 2012, 11:41 am
ken wrote:
Sean,
you're a fast mover, hope there's an invoice in there as well as the pipes.
Looks as though I'll have to tidy up that M4 motor to match the shiny new bits, or should I just fit them on this Visa engine? ;)
Visa engine by slcchassis, on Flickr
First time I've seen a naked Visa unit. Are they black as standard?
1973 Ami 8 Club
March 26th, 2012, 3:37 pm
A friend and I did something similar in a 602 engine we're renewing.
Except we used materials easier to work with (copper, brass and tin), then galvanised this to match all renewed bolts etc. I also went for oring seals to "save" some height because I had to make the joints slightly bigger (in diameter for a longer contact surface between pipe and joint body, and higher for a slightly thicker pipe). Due to that, I had to grind and smooth the attachment spots on the heads so the oring would sit flush and compressed. Totally works :)
March 28th, 2012, 12:01 am
wow looks good
i ran off a few when the new ones available would only last about a year on a road car and less on a racer the thin steel just seemed to fracture so i made some to get my car going over a weekend
March 28th, 2012, 7:57 am
I was a little uncertain about the materials, what you used is tougher (and looks better "raw"), but it seems to be fine.
March 28th, 2012, 9:22 am
ive used copper too as i was unsure how copper nickel behaved when heated cherry red - seems fine it also has a bigger bore than the copper and so carries more oil
March 28th, 2012, 6:14 pm
Users browsing this forum: No registered users and 124 guests
