View unanswered posts | View active topics It is currently February 22nd, 2026, 6:57 am
 Steering Column removal
Post Re: Steering Column removal
Something like this, perhaps... ;)
Modifiedsteeringcolumn by slcchassis, on Flickr
banjo wrote:
:roll: While you have it off ( no not that :mrgreen: ) make the slot in the bottom of the column a bit longer,either hack saw or angle grinder this will make it clamp better onto the steering rack.
January 20th, 2012, 3:24 pm
Yep did that with the one that's on atm as it was sliding up and down about half an inch when we got it. Still not got round to this hopefully will this weekend or next week. :roll:
January 20th, 2012, 4:51 pm
Mind having said that I haven't done mine as yet!!!!
January 20th, 2012, 5:29 pm
James,
make sure that the bolt is 10.9 grade (high tensile), as the yield stress of the 'standard' bolts (8.8 grade) used elsewhere on A series cars is too low for this location.
Also, the nut should be a nyloc type.
The worst substitute I've ever seen was a 6mm diameter roofing bolt, complete with its thin square nut.
If the column still moves even after the clamping bolt has been correctly torqued, might be a good idea to replace it...
Ken
January 20th, 2012, 5:32 pm
