View unanswered posts | View active topics It is currently June 19th, 2026, 7:16 pm
Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
 2cv Mods and Improvements (totally subjective) ( . ) ( .)
Post Re: 2cv Mods and Improvements (totally subjective) ( . ) ( .
Are you building an off roader/4x4?
December 31st, 2011, 9:49 am
Online
@dave111
Yes, slowly
December 31st, 2011, 10:36 am
Harley wrote:
The grease nipples seem the smart way to go, I can see the practicality of having them on the suspension arm bearings but where to put one on the steering rack?
CHeers,
DSC00128 by Sean602, on Flickr
that nut is M6 and takes a grease nipple when its all assembled ( with credit to Ken and Rick)
DSC00127 by Sean602, on Flickr
the pinion nipple : its possible to drill and tap the hole with the pinion in situ with it working perfectly afterwards- just dont drill too deep!
December 31st, 2011, 11:12 am
Online
Rack Needs 2 Nipples
Pinion Gearing.
Pinion Bearing
December 31st, 2011, 1:38 pm
Great pics Sean and Pete, thanks for those
This will be the new family car :) and I thrash the shit out of it on lots of dirt roads...
I was sandblasting the suspension arms and cross-members when i noticed that the front wheel hub bearings have play in them... replaced 8yrs ago... I assume that with the arm off and drive shafts out there should be no play in the hub bearing...
So, SKF are the top quality, what are the waterproof, made in France, ones like, any experience?
Cheers,
January 5th, 2012, 1:36 am
With the hub it undone you'll notice a lot of play in the wheel bearings, quite normal. It's when the hub it is done up and the drive shaft in that play in that bearing is a problem.
January 5th, 2012, 1:42 am
ahh, cheers, thanks Russ.
HArley
January 5th, 2012, 2:23 am
Cheers,
On the 4x4 I hace greaseable bearings. The hub is drilled and tapped for a grease nipple and then a snall channel cround into the bearing to alliow the grease to enter the bearing from one side. As I remember it the seal on the other side is reversed to let the old grease out.
Prior to this set up I was going tru bearings eery season but now I've done over 5 years on the last set. At the end of a days off road/play/fording just jack up the wheel spin it slowly and pump fresh grease in and the water filled stuff comes out.
Louis Barbour did the modifications and I think it is now standard to most of his kits.
January 5th, 2012, 11:07 am
Online
Alternative Approach...
Part 1
MEASURE VERY CAREFULLY..
Drill and tap 8mm hole between bearing and outer seal.
Use a Dremel to make a small grove in hub if required, (if the hole is drilled correctly this step is not required)
Fit 8mm grease nipple.
Part 2
Drill a 2mm hole between the bearing and the retaining nut.
Fit the nut and mark where the hole is located.
Use a Dremel to make a small grove in nut if required,
Part 3
Fit standard seals in the normal way.
Fit the drive shaft or a cut-off outer stub.
Grease and rotate the bearing at the same time.
The grease will fill the bearing and pass thru and come out of the 2mm hole..
ps No need to grind the bearing
January 5th, 2012, 1:08 pm
Part 1
Part 2
Part 3
Perhaps my bearing isn't ground and there is a groove in the hub. That would kind of make more sense.
Can't remember now and as I don't take them apart so regular any more I can't remember what exactly was done but you get the idea...
January 5th, 2012, 3:31 pm
Users browsing this forum: No registered users and 180 guests
