View unanswered posts | View active topics It is currently May 6th, 2026, 1:25 pm
Reply to topic  [ 62 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
 A new thread all about muffs.
Post Re: A new thread all about muffs.
James,
36 lb.ft torque needed... ;)
Compare that with wheel nuts, which need between 29 & 43 lb.ft.
Jameswallace wrote:
I've had the fan fall off a few times
Only time I've realised is when the engine smells hot in the cab!
And it will idle higher
November 12th, 2011, 7:17 pm
I find walking off after replacing fan and not the bolt is my biggest problem ;)
November 12th, 2011, 7:25 pm
James,
whatever you do as a pastime, please don't take up skydiving. :lol:
November 12th, 2011, 7:32 pm
ken wrote:
James,
its alright James only weighs half a kilo so he will float anyway :D
November 12th, 2011, 8:35 pm
ken,
i wont take up sky diving ;)
no the problem was is Chris and i put the car back together, and I was seeing Chris off and forgot to put the bolt in ;)
One smashed fan later (also hadnt fitted the fan guard) and a bent mesh behind the grille, lesson is learned
(best not talk about the oil filter incident also :roll: that was another case of being distracted ;) )
November 12th, 2011, 11:38 pm
lovin' the snatch
I will just add my 2 pennies worth here
i fit mine in the morning when its "really" cold.. right now im setting off at around 05:30 for work and by the time im a mile down the road i can already feel heat coming through to the demister or under the dash... but right now i havent got my muff fitted! although it'll probably be fitted either the end of this month or next month!
also it's a good idea to take it off if you are considering any long distance/motorway driving...
|-|-' 602 For Life :)
Keep Them Looking Standard.
1979 Myosotis Blue Dyane6
1986 Sunrise Red 2cv6
November 14th, 2011, 6:40 pm
Sometimes you've got to wonder why Citroen bothered printing owners' manuals... :roll:
November 14th, 2011, 6:56 pm
10 degrees or below I fit mine ;)
Handbook says 15 iirc?
November 14th, 2011, 7:41 pm
Mine ran like a bag of spanners with it on, took it off and it was much better. Guess I'll leave it to get a bit colder.
November 14th, 2011, 7:46 pm
how do the muffs fit on an early dyane?
November 15th, 2011, 7:20 pm
Users browsing this forum: No registered users and 133 guests
