View unanswered posts | View active topics It is currently May 6th, 2026, 1:25 pm
 Whats with the dim dip
Post Re: Whats with the dim dip
Paul,
the only logical conclusion, since Citroen _never_ got anything wrong... :roll:
( I'd best go in to hiding for a while, as the fundamentalists will be after my blood.
Might be able to fight them off for while with chunks of rusty chassis, broken fan pulleys, worn-out track rod levers and other bits of junk as ammunition... ;)
602 wrote:
I blame Volvo for it.
September 12th, 2011, 4:13 pm
emu_p wrote:
What happens under the dashboard re the diode holder???
Do I need to just remove it and tape up the empty connectors?? or join them together???
just leave it doing the jumper thing effectivley bypasses it, it also leaves a ignition on 12v supply if you trace the wire- usefull for radios and the like
September 12th, 2011, 5:37 pm
just checked wifes car and the two relays are mounted to the left of the battery one above the other which is the one that needs the bridging wire the top or the bottom one?
September 12th, 2011, 7:56 pm
They both need removing. You bridge the one with the same plug as in the posted picture above.
John Jordan
September 12th, 2011, 8:01 pm
one plug has 5 wires the other only four ....you bridge the one that has 5 wires and remove both relays
if you look very closely the terminals are marked with tiny numerals - its 1 and 5
September 12th, 2011, 8:30 pm
Also a good idea to fit relays to take the load off the headlamp switch,
Different mallter though
September 12th, 2011, 8:34 pm
Tis Done .... many thanks everybody
September 12th, 2011, 8:48 pm
Users browsing this forum: No registered users and 133 guests
