View unanswered posts | View active topics It is currently July 14th, 2025, 3:28 pm
Reply to topic  [ 235 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24  Next
 Belinda: on the road
Post Re: Belinda: on the road
Joe Ahvee wrote:
Sort of a work in progress. i guess with a car like that you sort of have a blank canvas to do what you like anyway!
Exactly, I always wanted a rolling restoration rather than have it off the road for longer than necessary. As I've said before - on the downside, I've got hardly anything to compare it to but as a plus, there's nobody to say "tut tut, that's not right"!! <awaits screams of disapproval from the rivet counters :lol: >
July 7th, 2010, 1:52 pm
I decided to start stripping Belinda's broken engine last night and I've got to say, with the engine on the bench and with the radio on, it was a real pleasure. Overall, the engine seems clean - everything came apart with the minimum of effort & once I'd got the crankcase split, the evidence of damage to the fuel pump rod (explained in a previous post) was clear
Compared next to a good rod, it's clear that the rod has indeed mushroomed inside the block. There appears to be no damage to the cam so as I'd done well for time I decide to quit while I was ahead and I can take my time to clean and inspect everything next week slow time.
July 9th, 2010, 1:36 pm
Having got the crankcase halves apart last week, I've cleaned the mating surfaces up & given the main components an initial clean last night to assess their condition. When I got the engine I was told it had done around 60,000 miles and to my (untrained) eye I don't really have any reason to doubt that.
The following pics do show what I have found though and I'd like your opinions please.
First of all, the cam that operates the fuel pump rod is scratched on the high point where it was mushrooming the rod itself. The cam hasn't changed profile, it's just scratched.
Next, there is a small groove in the inner surface of the crankcase hole where the piston fits through. I can feel it with my finger.
The pistons themselves are discoloured
and finally, the cylinders have one or two faint scores that I CAN'T feel with my fingernail
July 13th, 2010, 1:25 pm
Quick question - is there a good reason why I shouldn't use the air cleaner stay to mount a Harley Coil as shown below (as long as I keep LT & HT leads clear of hot metal)?
July 21st, 2010, 4:20 pm
i would *think* if its secure and the HT leads are clear of hot metal you should be ok? but i think there is a reason citroen mounted the coil near the grille (for cooling) but obviously its a bit different for you. thats not really much help is it? sorry!
July 21st, 2010, 4:30 pm
That's it - I can (and have) mounted mine behind the grill but it makes things a little difficult everytime I want to run the engine without the grill fitted (adjusting timing for instance). I know some have mounted it on the gearbox before but the air cleaner stay seems just as good.
July 21st, 2010, 4:38 pm
on the pick up my coil is mounted in that area so cooling shouldnt be too much of an issue
July 21st, 2010, 4:39 pm
I did a bit of interior fitting this week with some LED lights & even a TV. I got hold of a unit a while back that is actually a product that is designed to fit under a kitchen unit but as it operates off 12V, I thought I could build it into the storage area above the seats in Belinda
July 24th, 2010, 12:04 pm
I like that idea. is that built in sat-nav I see on the dash as well?
July 24th, 2010, 1:50 pm
Bump;)
very nice clear pics and descriptions here... can we have anyone comment on the condition of the engine*?
*(looks @ Mr Hanna and the Viking bastard :D )
July 24th, 2010, 2:32 pm
