View unanswered posts | View active topics It is currently May 1st, 2026, 9:00 am
Reply to topic  [ 4 posts ]
 Exhaust and Inlet gaskets
Post Exhaust and Inlet gaskets
Are the Exhaust manifold to cylinder head and inlet manifold to cylinder head the same gaskets?
April 25th, 2010, 2:47 pm
Post Re: Exhaust and Inlet gaskets
I put some on the wrong way round, and although they work, you get strange black goo running down the cylinder head from the exhaust end.
April 25th, 2010, 2:51 pm
Simon,
not only are their shapes different, but their composition is as well, since the exhaust end of the engine tends to be a bit hotter than the inlet.
Fitting inlet gaskets to the exhaust joint will restrict the outlet.
The gaskets won't last very long either.
Notwithstanding the above, I've found them fitted incorrectly on race engines, someone even managing to fit the exhaust gaskets at 90 degrees to how they should be located.
Pure genius... ;)
April 25th, 2010, 2:57 pm
Thanks Terpineol Thanks Ken just wanted to check
April 25th, 2010, 3:15 pm
Users browsing this forum: No registered users and 82 guests
