View unanswered posts | View active topics It is currently September 6th, 2025, 6:33 am
Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
 VW Beetle 1500 pistons
Post VW Beetle 1500 pistons
I'm toying with the idea of trying to mate a pair of VW 1500 pistons and barrels with a 2CV engine. Does anyone know if this will work, or is it up to me to pioneer this (and no doubt fail expensively :) )? The 1500 engine has a stroke of 69mm, as against the 2CV's 70mm, but I'm not sure about the diameters of the barrels. Can't find much on Google either. Any thoughts?
Incidentally, I don't feel the need for more power particularly, but since when was a project like this about "need"? :D
EDIT: Hmmmm, maybe I should have put this in "Technical".
March 20th, 2010, 9:53 pm
Post Re: VW Beetle 1500 pistons
moved! ;)
I posted this the other day in Harry's 652 thead:
Antony from Bandung West Java sent these pictures of his 1985 FAF - he had recently rebuilt his 602cc 2CV engine by using the pistons/sleeves from a 1500cc VW to upgrade his egnine size to 750cc. Sounds like good ole Citroenist ingenuity to add a few horsies to this rare 2CV derivative.
March 20th, 2010, 10:14 pm
That's where I nicked the idea from. :)
March 20th, 2010, 10:28 pm
:roll: :lol:
March 20th, 2010, 10:29 pm
For anyone else who may be interested...
http://www.vwheritage.com/vwh/VW-Beetle ... lateID=vwh
March 20th, 2010, 10:31 pm
Wow. Less than £150 for four barrels and pistons. Cheaper than 2CV stuff ;) .
March 20th, 2010, 10:48 pm
Because I like maths :shock: I can tell you that a 1500cc 4 cylinder engine with a stroke of 69mm should have a bore of about 83mm.
Compare that to a 602 2 cylinder with a 70mm stoke which should have a 74mm bore, although I haven't double checked that with haynes.
Incidentally, using 83mm pistons with the 2cv's 70mm stroke would give a capacity of 761cc.
HTH :geek:
March 21st, 2010, 12:39 am
HTH :geek:
You're absolutely right. I wonder how the chap in the link in Neil's post above managed to mate them to the crankcase?
March 21st, 2010, 2:23 am
I assume the crankcase is modified? I can't see it being a simple swap but I also wouldn't have though it'd be beyond the capabilities of a good machining firm.
March 21st, 2010, 9:12 am
I had a look at this years ago,
there is also the issue of the gudgeon pin and deck height as well as the head head, studs and push rod tubes
none of it impossible if you have a machine shop and too much time on your hands ;)
saw an engine once that used porche pistons think it was based on the visa, more meat on the barrel for increase in bore, but then you have to have the nickasil coating re done or have the barrel sleeved
sean
March 21st, 2010, 11:24 am
Users browsing this forum: Geert and 35 guests
