View unanswered posts | View active topics It is currently May 1st, 2026, 3:15 am
Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3
 Help your Reniflard
Post Re: Help your Reniflard
These are available on ebay that look very similar to those on offer from the boat shop....http://cgi.ebay.co.uk/WHALE-NON-RETURN- ... 1064wt_939
January 21st, 2010, 9:03 pm
I think that an important factor is overlooked. Engines with worn (out) barrels and piston rings allow compression to pass down to the crank case. Even new original Citroën breather will struggle to produce the vacuum needed. Tested a new UK valve just fitted on a raid 2cv not long ago. The result was interesting only showing 2 cm suction at high revs. Removed the valve and fitted the preproduction from South America and guess what, 0 vaccuum.
I guess the focus on the breather should shift to a compression test before replacing it.
January 21st, 2010, 9:18 pm
Thanks for that. I will order one to test it.
January 21st, 2010, 9:20 pm
tittap123 wrote:
The brass valve go positive due to moving masses.
See i wasnt making up about some valves not coping with the rapidly fluctuating pressures
:lol: :lol: :lol:
Went into the ships chandlers on my wanderings yesterday they were looking for £18 :o
January 21st, 2010, 10:04 pm
Well spoke to the firm and the whale valve is for water and not oil. They do not have anything similar to what we are looking for.
Lets start again, shall we :mrgreen:
January 22nd, 2010, 11:55 am
Yes, but replace the gasket is quite simple ;)
http://www.elevarsi.altervista.org/
January 22nd, 2010, 1:42 pm
Users browsing this forum: Google [Bot] and 134 guests
