View unanswered posts | View active topics It is currently May 24th, 2026, 2:07 pm
Reply to topic  [ 183 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 19  Next
 We have liftoff.....AZU 250 rebuild thread
Post Re: We have liftoff.....
yep, that was my decision ..... L shaped bracket, drill one hole, job done !
:lol: :lol:
May 12th, 2020, 11:03 am
Dagmars ??
Painted shells, got lots of runs, will be redoing !
May 19th, 2020, 5:45 pm
Thats a nice colour :)
May 19th, 2020, 7:24 pm
This is the Van that keeps giving ! Another 5 centimes to the rebuild fund :D :D
June 1st, 2020, 12:59 pm
Just checking.....
Front drums, is it utterly impossible to get the "3 way to drum" brake pipe fitted when the slave cylinder is fitted?
Another question, is it only possible to to assemble the front brakes if you have 3 arms?
I've got a Dyane box here and there is plenty of space between the gearbox casing and backplate but on the 602 box.....its very tight !
June 7th, 2020, 11:14 pm
48pop wrote:
Just checking.....
It is possible, I have done it once, but it is not advisable. You need very thin fingers and a lot of patience.
What I can advise is:
Adjust the brake shoe adjustment lugs so that the cylinder is exposed, so you can easily remove the cylinder and leave the brake shoes. After mounting the cylinders you can adjust the brake shoes again.
Piece of cake. ;)
No, two good arms will do.One left and one right . 8-)
June 8th, 2020, 8:19 am
It helps if you have an pet octopus ;-)
June 9th, 2020, 6:14 pm
Some more small tasks complete...
Originals media blasted, primered and sprayed.....
Headlamp bar Shortened, blasted and painted
June 14th, 2020, 11:53 pm
Looks great.
June 15th, 2020, 8:05 pm
Headlamp bracket shortened ? What was the reason and where did you shorten it ? Thnks
June 15th, 2020, 8:41 pm
