View unanswered posts | View active topics It is currently April 27th, 2026, 12:41 am
Reply to topic  [ 780 posts ]  Go to page Previous  1 ... 57, 58, 59, 60, 61, 62, 63 ... 78  Next
 Van repairs
Post Re: Van repairs
We are always left behind....
December 18th, 2018, 6:09 pm
If others start to lap you, it will look as if you are in front. :lol:
December 18th, 2018, 8:31 pm
Happy New Year you B*****ds :!:
I may as well start 2019 as I left off, messing with a probably knackered engine and gearbox.
ImageP1020280 by Robndaisy, on Flickr
So after 2 weeks of soaking, one nut loosened off nicely but see how dry it is between the end of the nut and the internal rubber seal. I guess that's why occasional heating is necessary. I didn't do that 'cos I was away.
ImageP1020283 by Robndaisy, on Flickr
The other one didn't want to move so rather than wreck it I was able to spring the pipes enough to unwind the whole unit off:it's gone back into the Red stuff, awaiting more attention.
ImageP1020281 by Robndaisy, on Flickr
ImageP1020282 by Robndaisy, on Flickr
Yep, the magnet is corroding :roll: .
ImageP1020294 by Robndaisy, on Flickr
Some corrosion on the cam lobe,
ImageP1020287 by Robndaisy, on Flickr
ImageP1020286 by Robndaisy, on Flickr
and also on two out of 4 followers.
The oil pump has also seen some water.
I'm hoping the cam and cam followers will polish up. I seem to have read somewhere? about a 'Clack' test for finding out if the big ends are ok. does anyone know how I can check it and the other bearings for excessive wear? Or should I just clean everything up, with new pistons and barrels, lap the heads,valves and fit appropriate seals and run it? This is my first time right inside a 602 and I know nothing about tolerances...but I'm willing to learn ;)
January 1st, 2019, 7:32 pm
I've never been right inside one.
Read a post where Ken said something along the lines of resting the crank on blocks and the whilst holding the con rod, tapping the big end upwards with a rubber hammer. If I recall, you may feel the 'knock', if there is one.
January 2nd, 2019, 10:31 am
Rob and Roger,
the technique which I use was demonstrated by a French chap in a video which I can no longer find.
The crankshaft is held in one hand, suspended by a conrod, then the little end is given a good thump downwards with your other hand.
(Gloves are advisable)
Any play in the big end of that conrod produces an audible 'clack'.
Repeat for the other conrod and if both are silent, you're good to go...
January 2nd, 2019, 3:44 pm
Thanks Lads!
Pssst!! do you know what is Golden?...Flamin' silence is :D.
Well worth the bruises :lol:.
January 2nd, 2019, 6:42 pm
Thanks Ken
That's good news :)
How is the gearbox looking :?:
January 2nd, 2019, 9:50 pm
It's still holding it's breath in the Tinto Rouge Derv. along with the cylinder heads etc. I've not enough space to have the engine and the gearbox lying around in bits (since the van departed the tent has become a slum):if Daisy was away,however, they'd be in the kitchen (where it's nice and warm) :) .
January 2nd, 2019, 10:37 pm
ImageP1020295 by Robndaisy, on Flickr
Getting soft in my old age, no more petrol washing. This stuff is supposed to leave an anti-corrosion coating on the parts.
ImageP1020296 by Robndaisy, on Flickr
Ready to be stored under the bed in the spare room.
ImageP1020297 by Robndaisy, on Flickr
First cleaning done, the cases will fit in the tub individually.
ImageP1020298 by Robndaisy, on Flickr
This is where the engine made long term contact with the soil. I'll have to get more aggressive with an angle grinder wire wheel for aesthetics.
Flamin' freezing out there, back to https://www.youtube.com/user/mustie1/videos ...run out of Gin so it's Brandy and tonic, an acquired taste :roll: .
January 9th, 2019, 10:29 pm
I tend to use a toothbrush size brass brush.
A dishwasher can get part surprisingly clean. :D
January 10th, 2019, 12:41 am
Users browsing this forum: No registered users and 278 guests
