View unanswered posts | View active topics It is currently May 1st, 2026, 5:55 am
 435 Dyane Heat Exchangers
Post 435 Dyane Heat Exchangers
The heat exchangers on my 435 6 volt Dyane are pretty shot anf ideally need replacing. Are this type specific or can 602 ones fit?
Also same question regarding the fuel pup - type specific or will a later 602 one fit?
If not, anyone out there got any of the above to sell?
Graham
February 7th, 2010, 9:51 pm
Post Re: 435 Dyane Heat Exchangers
I thought all 435/602 M28 engines, were 12v :?: I know the manifold is narrower on the 435, but I guess the heat exchangers are the same on 435/602 M28s
February 7th, 2010, 10:12 pm
Cheers for that - mine is a 6 volt car, probably the only one this side of the pond. 6 volt was an "option" according to the handbook. Probably cost a few francs less. Uses a magneto.
February 7th, 2010, 10:29 pm
Grumm,
the heat exchangers for a 435 engine and a 602 engine aren't interchangeable, unfortunately. :(
I guess you meant 'dynamo' rather than 'magneto', since the latter only produces sparks, not electricity? :roll:
February 7th, 2010, 10:50 pm
[quote="ken"]Grumm,
Cheers Ken,
You are, of course, quite right! Dynamo would have been the word I was looking for; somehow I chose to use magneto instead!
Thanks for the info - getting a second hand set of heat exchanders for a 435 will be a bit of a challenge.......may have to wait until the French National.
What about the fuel pump - interchangeable?
Regards
Graham
February 7th, 2010, 11:24 pm
Yep,
pretty sure that's OK, as I seem to recall moving over the relatively new fuel pump and clutch from a 435 motor onto the 602 which replaced it.
February 7th, 2010, 11:52 pm
Slightly off topic here(sorry), this is aimed at Ken...Which would you consider to be the better engine? I've heard the 435 never suffers from full/part seizure, unlike the 602, but the lower power requires greater use of the throttle and so the engine wears a lot quicker, true?
February 8th, 2010, 12:41 am
Jonathan,
in a 435 you go along in a modicum of style, as long as you don't want to get anywhere in a hurry!.
It needs to be strangled quite hard to get it up to speed, especially up hills - then again, my car is 42 this year so I forgive it!
Graham
February 8th, 2010, 6:56 pm
What's actually different about the heat exchangers? Is the crossbox the same?
February 8th, 2010, 7:46 pm
Grumm wrote:
Jonathan,
Graham
Thanks Graham, I quite fancy a 70s 4-light Special with 435, I think they are Uber-Cool. 8-)
February 8th, 2010, 7:55 pm
