subarupete
Joined: March 5th, 2009, 6:23 pm Posts: 2251 Location: Near Monmouth
 Re: Transfer box.. A new version...
The saga so far..... Standard parts, Modified Parts and new parts. The "new" parts not yet, necceassarly in the correct order  Some of the bits to do ... Oil Seal for selector rod, and (gear) lever for selector rod. Estimated additional total weight about 14Kg  Attachment:
| June 26th, 2024, 1:33 pm |
subarupete
Selector rod parts. Seal and interlock. Attachment:
| July 2nd, 2024, 6:42 pm |
subarupete
Selector Lever... Ouput Engaged. Attachment:
Output Disconnected. Attachment:
Access to Oil filler & level a bit comprimised  Attachment:
| July 6th, 2024, 11:11 am |
jasu
Joined: August 8th, 2012, 11:00 am Posts: 503 Location: Korpilahti, Finland
Bend that lever. A tight bend just over the uniball, and another over filler plug to the direction desired. Problem solved..?
| July 6th, 2024, 1:57 pm |
subarupete
Feasable, also have a spare one of these Attachment:
| July 6th, 2024, 2:45 pm |
subarupete
Fits together but will it fit in the car?  Attachment:
| July 8th, 2024, 12:10 pm |
Geert
Joined: July 10th, 2010, 12:35 pm Posts: 1186 Location: Magyarország
Fingers crossed !
| July 8th, 2024, 2:14 pm |
subarupete
Re-made the Bearing retainer and oil seal holder, was somehow out of alignment  Attachment:
| July 15th, 2024, 5:19 pm |
subarupete
After some very careful measureing  , I can fit a triplex chain and sprockets, whick only adds 5mm to the caseing depth. Had to redo the selector interlock....etc Attachment:
| July 16th, 2024, 8:41 pm |
subarupete
Trial fit with a a dummy chassis rail, its a very tight fit!! Attachment:
However if I reduce the height by "20mm" not so tight. Attachment:
Means I have to make a new back plate:( Attachment:
| July 30th, 2024, 10:51 am |
Users browsing this forum: No registered users and 98 guests |
