View unanswered posts | View active topics It is currently May 1st, 2026, 7:04 pm
Reply to topic  [ 8 posts ]
 Wheel stud removal..
Post Wheel stud removal..
Has anyone removed the wheel studs from an Ami Super hub before, doesn't seem to be the same as a 2cv hub, there is no weld on the back!! Is it just pressed in there??
Dyane 12 1976 (ish)
April 17th, 2013, 7:58 pm
Post Re: Wheel stud removal..
so-- no ones replyed
if they arnt welded just use a hammer to blugion them back out backwards
but why?
April 18th, 2013, 2:09 am
Firstly, no, I've no experience with them, But if there's no weld I would assume they're just pressed in, probably on splines, hope that's not going to be a problem. Rather than 'bludgeoning' them, if you can easily take the hub off, try pressed them out with a vice, with a large socket or similar over the back. Ether way, remember to protect the thread by putting a nut on while you're doing it.
April 18th, 2013, 2:29 am
but why?
You ain't been reading my thread then!!??
Need to fit longer studs, so the alloys will fit on over the spacers, that will then solve the clearance issues!! Simpols!!
Dyane 12 1976 (ish)
April 18th, 2013, 11:50 am
Hi Matt
Is that ODA***X in your Avatar??
Cheers
Boggy
April 18th, 2013, 8:37 pm
Boggy wrote:
Hi Matt
Cheers
Boggy
viewtopic.php?f=5&t=2130
April 18th, 2013, 8:53 pm
cheers Neil
Does anyone know what happened to ODA***X after 2009??
Cheers
Boggy
April 18th, 2013, 9:03 pm
Think I might have to take the hubs off and stick them in the vice, looks like I might aswell do the wheel bearing whilst I'm at it!!!!!!!
Wonder what I'll be upto over the weekend then!!
Dyane 12 1976 (ish)
April 19th, 2013, 12:15 am
Users browsing this forum: No registered users and 79 guests
