View unanswered posts | View active topics It is currently February 22nd, 2026, 1:10 am
Reply to topic  [ 7 posts ]
 Strange headlight fault
Post Strange headlight fault
I've got all the wiring rigged up but only the right hand headlight works... They have been fused into the original fuse box, I can get an ohms reading from the fuse to the right hand headlight but not the left, same as from the switch to the headlight.
*idea* perhaps both headlights have separate fuses, i'll go check...
Cheers
August 1st, 2012, 9:42 am
Post Re: Strange headlight fault
I would be tempted to put new wiring in with a new fuse box.
August 1st, 2012, 10:29 am
And you did ;)
I saw your thread and it looks so good! But I need to drive this car out of here 3days ago.
I have sorted the problem, separate fuses for each headlights, even though it had a fuses it was a bad connection...
Cheers!
August 1st, 2012, 10:52 am
yes each headlamp is seperatly fused , bad connections are common on the original connectors&fuse box
does your 2cv still have the "dim dip" system?
August 1st, 2012, 12:28 pm
I have nfi what the dim dip system is although I have seen it written about in many posts.
When I get back from the raid I will rewire it all as all the wires at the light bar are cracking...
August 1st, 2012, 1:22 pm
its a strange addition to the wiring harley, when u switch the sidelights on and turn on the ignition, the dipped headlights glow slightly as well
theres more info in the forum about it
August 1st, 2012, 2:45 pm
Ayjay, dim dip was a UK thing till the euro manufacturers put an end to it.
August 1st, 2012, 8:27 pm
Users browsing this forum: No registered users and 113 guests
