knightley
Joined: June 19th, 2010, 8:40 pm Posts: 761 Location: Kingswood, S.Glos.
 Re: Van Insulation
My brother used that stuff in his house extension. It is expensive, but very flexible. The blurb says it has the equivalent insulation properties as 50mm traditional rockwool/fibreglass.
_________________ John Jordan
| June 28th, 2012, 3:44 pm |
602
Joined: July 21st, 2010, 7:12 pm Posts: 859 Location: Chatenet, France
 Re: Van Insulation
Glue is never going to be an issue, my son works for Bostik. Its a balance between finding something with the right insulation properties, flexible enough to fit all the curves but looks reasonable too.
As I am taking the body off this winter for some serious attention, I can do all of this with the body upside down which has got to help.
| June 28th, 2012, 3:53 pm |
Little Louis
 Re: Van Insulation
This with some foam over the top, maybe carry matts will give really good results. http://www.caraudiodirect.co.uk/chp-alu ... g-mat.html
| June 28th, 2012, 3:57 pm |
602
 Re: Van Insulation
Whilst that may well stop me disturbing the peace while playing Led Zep at full tilt, not sure it will keep 45C sunshine from cooking the occupants of the van though
| June 28th, 2012, 4:03 pm |
Smiffy
Joined: October 23rd, 2009, 10:41 pm Posts: 2356 Location: Worcestershire
 Re: Van Insulation
Here's some more info about Triso super 10 properties Attachment: triso info.jpg
| June 28th, 2012, 4:10 pm |
2CViking
 Re: Van Insulation
I doesn't matter how much insulation you stick inside the van, it will still be warm. The trick is to get rid of the warm air letting air through. The blue van is from The Netherlands not made by me. All sort of things has been tried down under (50 dg in the outback) Ventilation is your friend.
| June 28th, 2012, 5:13 pm |
602
 Re: Van Insulation
I am working on doing both. Expecting the Sahara to be hot in August.
| June 28th, 2012, 5:20 pm |
Geert
 Re: Van Insulation
I have seen some Landrovers with an extra "double roof". They use them in the desert
| June 28th, 2012, 7:05 pm |
Smiffy
 Re: Van Insulation
Oh yeah... like this Attachment: 2cv in desert.jpg (swiped from Ernst van Altena's book)
| June 28th, 2012, 7:13 pm |
Solexman7
Joined: January 2nd, 2012, 2:33 am Posts: 18 Location: MELBOURNE, AUSTRALIA
 Re: Van Insulation
The Vent in the Grey Van is my AZU250, it works really well in the hot weather and keep the driver's cab cool. They are from an early Toyota Landcruiser if you can find one at a wrecking yard. Cut the whole panel out and cut and weld it in. Cheers from OZ, Geoff
_________________ Melbourne Australia 1968 2cv AZU 1949 Solex 45cc 1956 Solex 660 1959 Solex 1700 1962 Solex 2200 2x 1968 3800's
| June 29th, 2012, 5:37 am |
Users browsing this forum: No registered users and 115 guests |
