View unanswered posts | View active topics It is currently May 2nd, 2026, 9:03 am
Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Supercharger
Post Re: Supercharger
RE: Sequential Ignition
Is it enough information for Megasquirt to use a single toothed wheel at the cam with a VR sensor to run full sequential fuel and spark? Or do I need to use a 36-1 trigger wheel pattern?
I currently have a MS1 unit and will upgrade to the MS3 to control ignition timing.
Cheers,
May 25th, 2012, 5:36 am
Cheers,
Did some stuff with Megasquirt.
36-1 hole drilled in a flywheel works perfect, but no sequential. Advantage (to crankshaft), no jitter do to the play between crank and camshaft and a skewed?? camshaft.
1 hole in flywheel (not bad running but bad cranking/starting) sensor at 10 degrees tdc.....
so 1 tooth at camshaft won't work, it takes to to much time till the next pulse so ignition can be way off then.
The best way for me would be a 4-1 better 8-1 better 24-1 best 36-1 toothed wheel 60-1
is overdone (my opinion) at crankshaft (VR sensor) and 1 tooth at camshaft (hallsensor)
Because at a 2cv you have 1 spark event every revelution, you can do with 1 tooth cq hole
at about 45 degrees crankshaft between sensor event and spark is less then 10 degrees so this is very acurate (again for a 2cv). For engine's with more cilinders
it will be worse again it would take to long timing can be way off. You can eleminate this by making a prediction when the next spark has to come (I'm working on this one)
so then it will be possible to make 3/4/6/8 cilinders decent running
May 25th, 2012, 11:11 pm
Thanks lpgo, that is much clearer for me now,
Taken from Microsquirt DualSpark...
Microsquirtis another, maybe the best, option for 2cv. based on the Megasquirt II extra code, in a water proof case the size of a credit card :shock:
A little confused by this statement, but I get the basic idea, i think, basically :?
thank you!
May 26th, 2012, 6:10 am
Hi legends,
I think I have fallen for the Microsquirt, instead of upgrading the daughter card to the MS 3, because it is more rugged, smaller, can do everything I need...
My set up is supercharged, 652cc, 2cylinder engine, multi point injection with twin spark plugs (2 in each cylinder)
I need to know how to run 2 coil packs (wasted spark type setup), one for each cylinder.
I know Microsquirt can do this but I read that the new V3 doesn't allow direct coil control;
"Logic level ignition outputs only - coil drivers have been removed." Taken from DIYautoTune andMicrosquirt website
So, what coils should I run for my setup and how to drive them with Microsquirt?
I will use the 36-1 wheel at the crank and single tooth at the cam like pic above...
Cheers!
May 26th, 2012, 1:17 pm
Here is a bench-test video of a 2cv running an amr300, SU carby and sparking with a 123 ignition:
It all fits in nice and neat. I guess they will run a modified/external oil cooler.
http://www.vgs2cv.be
June 12th, 2012, 3:38 am
Any Idea make/model of super charger??
June 12th, 2012, 9:08 am
It says AMR 300.
John Jordan
June 12th, 2012, 9:12 am
Yes, it is Aisin AMR300, the same as I have, they come up for sale regularly on Australian Ebay, around $AUD350. I can purchase and post one to you if you like Pete!
June 12th, 2012, 10:31 am
Harley,
I am tempted.
How much to ship to UK?
Have you got Paypal?
June 12th, 2012, 2:10 pm
subarupete wrote:
Harley,
I am tempted.
I weighed it years ago at 4.5kgs
Shipping is $70 by sea and $140 by air for up to 20kgs , more for tracking etc
http://auspost.com.au/apps/international-parcel.html
Sent from the future (my phone) so link may not work...
I have paypal .
June 12th, 2012, 3:22 pm
Users browsing this forum: No registered users and 82 guests
