View unanswered posts | View active topics It is currently May 27th, 2026, 9:44 pm
Reply to topic  [ 5655 posts ]  Go to page Previous  1 ... 335, 336, 337, 338, 339, 340, 341 ... 566  Next
 The O/T thread!
Post Re: The O/T thread!
Do you think this might want a head gasket?
April 27th, 2012, 10:09 pm
or you got very excited when you removed it...
April 28th, 2012, 12:37 am
Is that off your van?
Don't jump the gun, the oil cooler tht the filter screws onto is prone to allowing oil and water cross contamination....... :ugeek:
April 28th, 2012, 8:48 am
Nah it's off the fork lift. It's always had a bit of mayo in the rocker box but we put that down to it being gas powered and that it's never run for long enough to get warm. I managed to convince my employers it wouldn't hurt to give it an oil change and all that came out of the sump was about one litre of this gunk. It lasted about a week before it wouldn't start and wouldn't turn over, I took the plugs out and one pot was full of water. It's meant I haven't had to do much work this week though. I changed the head gasket and now the starter motor brushes have worn out and no amount of cleaning them and bending things in the top of the motor can make it work properly for long enough to start it until the brushes/commutater burn out. So until the new starter turns up on Monday I won't know if I've fixed the head gasket or whether the head, which I had to weld as it was eroded away above the gasket, is scrap. I love my job.
April 28th, 2012, 9:17 am
My boss still hasn't done an oil change after 50 k in the caddy van
Checked the oil the other day, was off dip stick
1.5 l later it was at the correct level!!
Also hard to get into gear. Gearbox oil change may help?
April 28th, 2012, 9:55 am
While most of it is riveted together there was some primitive looking stickwelding still visible.
great OT post!
Think the electric welding process was developed to weld armour plate or at least it sped up the development - the metallurgy dictated that stainless electrodes were used to arc weld field repairs hence the shiny weld. factory welding used shielding gas to protect the integrity of the weld.
youve discoverd my guilty secret! dont get me started on German tanks :geek:
April 28th, 2012, 11:34 am
Didn't see the tank post until Sean quoted it. I will have to have a look at that i love stuff like that
April 28th, 2012, 11:39 am
great OT post!
You need one of these:
http://www.amazon.co.uk/BB-German-Tiger ... 932&sr=8-3
April 28th, 2012, 2:27 pm
ah last and heaviest of the box hull pre war designs , then they met the radical t34 with the sloping glacis plate and the Christie suspension, and had to start again with the panther and the Tiger II using complex engines and epicyclic drive that conserved all the engines energy - sloping armour and 88mLl71 armament that could knock out anything about a mile before their opposition could even get close enough to get a hit on them.
bloody Germans making things properly for decades.
April 28th, 2012, 5:41 pm
I've never run out of juice on a bike, but I have pushed a ford Capri a mile or so to a petrol station.
Just flicking through this thread. But if i remeber rightly you mike and my self stood back and let the girls push it to the petrol station
May 1st, 2012, 11:49 pm
Users browsing this forum: Roger V, Taskos and 80 guests
