View unanswered posts | View active topics It is currently May 6th, 2026, 8:37 am
Reply to topic  [ 372 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 38  Next
 Yellow Dyane
Post Re: Yellow Dyane
Why you want them off?
June 7th, 2021, 4:18 pm
To fit to the new chassis.
ImageP1030369 by Robndaisy, on Flickr
I couldn't get the flamer to turn cold and didn't want to heat the flamer up in case I disturbed the high tensile metallurgy stuff, so ground away enough of the threaded bush and then some hammering of it to expand the flamer and it gave up :) .
I'm too mean to buy a 26mm. spanner just for this job.
June 7th, 2021, 7:45 pm
I got real and warmed the threaded bush with a Gaz blowlamp until the thread sealant melted, out they came dead easy. :)
June 8th, 2021, 6:24 pm
They stil look in good shape seen the rust around.
June 8th, 2021, 9:31 pm
https://ecas2cvparts.co.uk/collections/ ... -2cv-6252a
Quite pricey if you needed 4.
June 9th, 2021, 1:46 pm
ImageP1030386 by Robndaisy, on Flickr
Took last week as a holiday, here we go at this back door bodyshell repair.
ImageP1030377 by Robndaisy, on Flickr
Where the lower C post? joins the sill, this outer corner brace has a friend on the inside too. That makes a four piece laminated rust explosion; anyway, I will re-use this.
ImageP1030380 by Robndaisy, on Flickr
profile with one layer removed.
ImageP1030384 by Robndaisy, on Flickr
Had to modify the end of the repro sill as usual.
ImageP1030395 by Robndaisy, on Flickr
I'll sort that out when the bodyshell has been inverted.
ImageP1030392 by Robndaisy, on Flickr
The door and it's gaps look OK, the top hinge mount on the B pillar has stress cracked, so I'll braze that up later...probably much later ;)
ImageP1030397 by Robndaisy, on Flickr
Not pretty but strong enough.
ImageP1030394 by Robndaisy, on Flickr
A different curved profile on the repro,
ImageP1030393 by Robndaisy, on Flickr
Different width too :roll: ,note the gap between the edge of the floor pan and the sill, there was a lot of factory mastic in there, in fact that's all that was left :lol: .
The one on the other side of the car doesn't look as bad, but we all know what it'll be like :) .
July 26th, 2021, 11:41 pm
Well happy welding...
July 27th, 2021, 5:01 pm
ImageP1030401 by Robndaisy, on Flickr
Why the B post rusted through behind the top right passenger door hinge I don't know, but I need to fix it so I can check the gaps before welding in the new C post...
ImageP1030399 by Robndaisy, on Flickr
once that was attended to, I could cut and fit the C post.
ImageP1030402 by Robndaisy, on Flickr
Fitted the tailgate before welding, just to make sure nothing started to move.
ImageP1030405 by Robndaisy, on Flickr
ImageP1030404 by Robndaisy, on Flickr
If I was restoring the car, I'd fit new inner wings and a new boot floor, but this is a re-build so I'm patching in new pieces, gonna need more Cleco clamps!
ImageP1030403 by Robndaisy, on Flickr
Citroen used a lot more body mastic on the Dyane compared to the 2 2cv, and it's helped the rust to really get going :roll: , this is just from around the area I'm working on :x .
My auto darkening welding helmet has gone on strike so no more welding for a bit, thank Flame :lol: .
August 21st, 2021, 7:14 pm
ImageP1030410 by Robndaisy, on Flickr
Damn! Screwfix got this in for me too quickly, no more excuses...
ImageP1030408 by Robndaisy, on Flickr
the little ball of wire is not your friend when plug welding into 6 mm. holes, so snip it off each time. Note: that is the boot drain hole in the picture, which I am not going to block up :lol: .
ImageP1030411 by Robndaisy, on Flickr
Just a few more patches and the quilt will be ready to turn over ;) .
August 31st, 2021, 8:45 am
ImageP1030412 by Robndaisy, on Flickr
Wow! that was some earthquake ;) .
September 3rd, 2021, 8:36 pm
Users browsing this forum: No registered users and 260 guests
