View unanswered posts | View active topics It is currently July 23rd, 2025, 2:51 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 197, 198, 199, 200, 201, 202, 203 ... 400  Next
Sounds likely that it's not timed properly using the static method
December 28th, 2013, 6:28 pm
Today i'm in a good mood on buying two 2CV's from 1974 for just 250 euros but we will see :D
December 28th, 2013, 6:43 pm
:shock:
Very cheap! pictures please. :D
December 28th, 2013, 6:45 pm
Even with these fully electronic ignition units, I'd suggest that it's _always_ worth checking the total advance using a strobe.
I had to send one brand new unit back to the manufacturer because the ignition advance was around 15* less than it should have been.
Hardly surprising that the engine seemed rather sluggish... :roll:
@ Warren,
how many miles did that set of points last?
Static and full advance marks should still be on the flywheel, btw.
December 28th, 2013, 7:12 pm
Ken, I've done about 13,000 miles since you last saw the car, the points were still fine, but I liked the idea of maintenance free so thought I would get ahead of myself before they needed attention.
I think I need to get the car up to you soon, the brakes are getting squeaky at low speeds, though they still pull the car up firm and square, I think the front n's may be grabbing as the car body seems to get pulled down diagonally to the n's front just as I come to a stand still, accompanied by some brake graunchiness. A mate of mine reckons it's a suspension problem of some sort, which it could be, but I'm inclined to think it's brake related.
I've been doing general maintenance things like oil & filters and greasing myself, but I'd rather brakes and suspension were seen to by an expert.
December 28th, 2013, 7:48 pm
Met up with a load of Brits at a regular classic car meeting that I didn't know existed. Drove little Réne there and back over hills and valleys - no probs.
Visited a guy on the way back with 7 Messerschmitt car and a bunch of other 3 wheeler "jetson" cars. They looked fantastic.
Good day out and met a lot of contacts for paint, engine work etc.
Better get him in the garage as I also found a few leaks on the way, had to drive with a towel over my legs to keep dry ;)
December 28th, 2013, 8:29 pm
Warren wrote:
I fitted 123 ignition. I followed the instructions carefully and read up elsewhere too and watched the videos before proceeding, I'm very thorough and can't see how I have got anything wrong or done anything other than a textbook job, each step checked, double checked & triple checked. And yet I'm underwhelmed. It seems to go similarly to before in terms of pull, acceleration, top end etc., but it now seems just a touch unresponsive, especially when I blip the throttle at idle, the revs don't seem to zip up as readily as before, and I'm getting a bit of a damp sooty exhaust patch on the drive too where the tailpipe points downwards.
the 123 wont make the car magically better than a well set up engine on points
they are better than a failing condenser
they are better than a worn points cam
they don't need adjusting every few 10s of 000s of miles
other than that that they can be prone to having wonky advance curves and dont like a suspect battery.
an advanced engine will seem crisper and more responsive but will also self destruct when pushed. A safely set up engine often seems sluggish by comparison but you wont sieze it , the oil leaks will dissapear and you wont be tipping oil out your filter housing.
December 28th, 2013, 8:51 pm
And here are some pictures :)
Uploaded with ImageShack.us
December 28th, 2013, 9:25 pm
this is the other one
Image2CV
This 2CV is partly restored and held in a warehouse for 10's of years and looks realy good for it's oldness
December 28th, 2013, 9:29 pm
I would love to drive the first one just as it is. What a bargain though!
December 29th, 2013, 2:36 am
Users browsing this forum: No registered users and 67 guests
