View unanswered posts | View active topics It is currently July 27th, 2025, 1:35 am
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 179, 180, 181, 182, 183, 184, 185 ... 400  Next
Looked at mine and thought 'must order that chassis'
September 26th, 2013, 6:30 pm
Yesterday I washed mine and have tucked it away now for the weekend 8-)
1988 2CV Special
1969 Singer Chamois
September 27th, 2013, 9:29 am
Hit a badger and broke the chassis.
September 27th, 2013, 7:50 pm
Part of the Cull?
September 27th, 2013, 7:54 pm
Pootled around the Peak District on various single track gated roads this morning, then went to the pub and over a few pints read Simon Days book A Tale of Two CVS.
September 27th, 2013, 8:04 pm
Really? :o Where'd it break? And I dunno if I dare ask this for fear of opening the worlds biggest can of worms but what make of chassis is it?
September 27th, 2013, 8:29 pm
Must be a B thing with chassis's - Badger, Barrier
September 27th, 2013, 9:04 pm
So, half past four this morning I'm seeing how fast the 2cv would go down the A24, when this stripy tuberculosis ferry jumped out in front of me, the tacho was reading 6800-7000 so I was going at a fair speed. When I hit the furry bellend it felt like I'd hit a block of cement. The passenger door burst open then slammed itself again, the car I'd just flown past undertook me so it slowed me down a fair bit. The exhaust was suddenly very noisy and the steering wheel had moved round 90deg. On top of that I've found there's no handbrake and the clutch cable is pretty badly damaged. The crossmember that the handbrake is mounted on is made from 3mm sheet folded into a channel, both webs of the channel are torn off the longerons and its smashed flat, it's also hit the bottom of the gearbox which is now leaking, and I assume is now Donald ducked. It is a frome chassis which are shite anyway, but now not only are they a dreadfully designed they're weak and feeble when faced with a minor impact such as hitting a small animal at 75mph. Lucky it weren't a cow or a buffalo or something really. Thankfully people have been very sympathetic, my girlfriend for example, upon hearing this replied to my text with 'OMG is the badger ok?'
Stripy little monochrome twat.
September 27th, 2013, 9:10 pm
Sounds like you have been a lucky boy!!!! keep the two pipes from the crossbox (thinking about engine test bench)
September 27th, 2013, 9:21 pm
I've not forgotten that, the steel arrived yesterday so Monday morning I'll start building it.
September 27th, 2013, 9:33 pm
Users browsing this forum: Bing [Bot] and 57 guests
