View unanswered posts | View active topics It is currently July 27th, 2025, 10:05 pm
Reply to topic  [ 3993 posts ]  Go to page Previous  1 ... 166, 167, 168, 169, 170, 171, 172 ... 400  Next
banjo wrote:
Little Louis wrote:
Drove 900 miles in 17 hours and 36 minutes yesterday, including waiting for the tunnel, taking the tunnel and petrol stops.
Where in La belle France are you now :) ?
England :/
August 7th, 2013, 5:04 pm
Little Louis wrote:
England :/
It was a senior moment,you were on the way back :oops:
August 7th, 2013, 5:09 pm
Lenny wrote:
Mine failed the MOT today
Badly?
Fail
Nearside inner wheel arch corroded
Offside inner rear wheel arch corroded
Offside front floor excessively corroded (The floor is like Fred Flintstone :shock: )
CO reading high
___
Advisory
Nearside Front king pin play
Offside Front king pin play
___
Nothing that can't be sorted - Hoping to get that all done in time for her trip to National end of the month 8-)
1988 2CV Special
1969 Singer Chamois
August 7th, 2013, 5:12 pm
I'm back in Worcester to get the 2CV MOTed and take her to Shetland to live. Since I knew I was leaving it for a few months in Worcester, I disconnected the battery before I left for Shetland, so that was the first job this morning. It wouldn't start. :shock: :? :( So I went though a check list and just ticked off things as I went. There was fuel in the tank, there was a feed to and from the coil when ignition was on, so as there was no smell of petrol under the bonnet I suspected a fuel delivery issue was the problem. I whipped out a spark plug and it was as dry as Gandhi's Flip-Flop! A quick text to Spanners of this parish, a quick reply read, and I was off to the petrol station for a wee drop of flammable liquid. A wee, wee drop of petrol in the carb got the car going and it's now over at Peter Cross' in Tibberton for a fettle/check-up and MOT tomorrow. Hopefully have it back by the afternoon and I can get it booked on the Aberdeen ferry to Shetland next week. Fingers crossed. :)
August 7th, 2013, 5:38 pm
God they are strick in the UK. What does it matter if wheel arch is corroded?
August 8th, 2013, 4:54 pm
If the corrosion is close to the rear outer seatbelt mounts, then that's a fail.
August 8th, 2013, 5:06 pm
If the reason for MOT failure is that there's corrosion within a distance of 300mm from a rear seat belt anchorage, then it depends on whether you want the rear seat belts to be more than decorative.
In France, apparently some offcuts of tin can, a bag of pop rivets and a tub of bondo are sufficient to restore structural integrity... ;)
August 8th, 2013, 5:10 pm
Just collected the 2CV from Peter Cross and it's a pass on the MOT. Had to replace the nearside headlamp bulb as the mainbeam filament had gone, and there was a poor earth on the offside front sidelight to sort before the MOT. Also had the handbrake adjusted.
August 8th, 2013, 5:14 pm
[quote="ken"]If the reason for MOT failure is that there's corrosion within a distance of 300mm from a rear seat belt anchorage, then it depends on whether you want the rear seat belts to be more than decorative.
I see - rear inner wheel arch :oops: :oops:
August 8th, 2013, 6:30 pm
160 k road trip of the lanes in the Charente with a visit to Verteuil-sur-Charente,for coffee and cream tea.Then on through the fields of Sunflowers ( sadly flattened in the recent storms ) to Mansle and thence back home to Manot.
August 8th, 2013, 7:07 pm
