View unanswered posts | View active topics It is currently May 1st, 2026, 11:02 am
 MOT incompetent tester.
Post Re: MOT incompetent tester.
;) Nice one :lol:
April 27th, 2013, 9:19 pm
Not sure about incompetence but I'm sure that there are plenty of dodgy/bent MOT testers. My Escort van has turned out to be more rotten than a pear and has a clean MOT with no advisories. If it got through its last test without the help of a bribe then I'm a monkey's uncle.
April 27th, 2013, 10:26 pm
going to go with Russ.s approach in a weeks time when i mot the 106 with no peroration i'm not to confident.... going to present it the earliest i can, so that gives me just under a month to fix it or drive it through the sea lots of times before i weigh it in at the local breakers...
then ill buy another!
April 28th, 2013, 12:16 am
Cruel
April 28th, 2013, 9:21 am
Jameswallace wrote:
going to go with Russ.s approach in a weeks time when i mot the 106 with no peroration i'm not to confident.... going to present it the earliest i can, so that gives me just under a month to fix it or drive it .....
Except that (apart from a few exceptions) it's illegal to drive a car on the road that is not fit to pass an mot and your insurance company probably won't cover you. :(
Jameswallace wrote:
.... or drive it through the sea lots of times before i weigh it in at the local breakers...
Don't do that. I'll give you a few quid for it ;)
April 28th, 2013, 9:52 am
Well if it fails v badly ill buy another and rob the engine, gearbox, exhaust etc for spares..!!
April 28th, 2013, 11:37 pm
I've never had any car fail an MOT in 20years*. Not miraculous, just planning and preparation - I take it in to my specialist for a service and MOT. They sort out anything needed for the test first, after letting me know any issues, then take it to be MOTd.
(*though to be fair I did sell the last CX a week before it needed one).
May 2nd, 2013, 11:45 am
My Dyane failed yesterday on corrosion in the front floorpan. I appreciate that this needs fixing and fixing properly, but the reason he's given on the ticket is that it's corrosion within a specified distance of a suspension mount. Surely that's irrelevant, since the suspension is mounted on the chassis? Not that I'll be appealing it or anything ... as I say, it needs fixing anyway and the chances of me ever doing it without an MOT fail to push me into it are small. :)
May 2nd, 2013, 2:58 pm
I was reading a similar topic on autoshite, basically it's distance that seems to count not location.
http://autoshite.com/phpbb3/viewtopic.php?f=1&t=16493&sid=d62ea47975f43d61a8144fe84419ecc5
May 2nd, 2013, 4:01 pm
Probably just picked the wrong fail point from the list, since it'd be a fail within 30cm of a body-chassis mount or a seatbelt mount - and that don't leave much...
May 2nd, 2013, 4:21 pm
