View unanswered posts | View active topics It is currently April 29th, 2024, 10:08 am
Reply to topic  [ 3 posts ]
 Spark plugs
Post Spark plugs
what size spanner do spark plugs for a 2cv use?
September 17th, 2009, 11:57 am
Post Re: Spark plugs
At a quick remembering I think its 21mm, I may however be wrong.
I'm fairly certain I normally use a 22mm deep socket which is a slightly loose fit.
September 17th, 2009, 3:28 pm
Nope, you're bob-on. It's the usual "large plug" 21mm - same as the sump/gearbox plugs - but most socket sets'll have a "proper" plug socket in them, with the 'ickle rubber widget in to keep hold of the plug as you pull it out.
Remember - fingers only to get it in as tight as you can, then just a quick nip with a ratchet or similar - and only put plugs into COLD heads.
September 17th, 2009, 3:33 pm
Users browsing this forum: No registered users and 350 guests
