View unanswered posts | View active topics It is currently July 2nd, 2025, 6:42 am
Reply to topic  [ 6 posts ]
 Look after your Steering Rack.
Post Look after your Steering Rack.
As the rack needed a “rebuild” have added these grease nipples.
1. Steering Pinion Bearing.
2. Steering Pinion.
3. Guide Ring.
The short piece of brake pipe goes the the steering tube into the guide tube.
Grease can be pumped in with the rack at various positions.
October 1st, 2021, 1:07 pm
Post Re: Look after your Steering Rack.
nicely done :)
October 1st, 2021, 1:22 pm
That is awesome.
October 4th, 2021, 11:20 pm
Online
:D
Thank you for posting !
October 5th, 2021, 7:23 am
Some Citroen U23 trucks had an inbuild greasing system. A reservoir on the firewall and a pedal operated pump. Brakelines for grease trough all the truck. So every now and than a kick on the pedal kept all greased up.
October 5th, 2021, 4:40 pm
Some Bentley and RR had a grease pedal too. Great idea.
October 5th, 2021, 10:42 pm
